Maxwell-8 4,366 #1 Posted December 23, 2024 I am looking at buying a Belgium made Raider 10 6 speed. Did some of them have the 10 pinion limited slip drive? Any way I can determine it has one without a tag number? Looks like a decent machine, original light kit, dial a height, electric clutch. 2 Share this post Link to post Share on other sites
pfrederi 18,322 #2 Posted December 23, 2024 Is there a short pipe nipple extension on the fill plug (left side of tranny)? That would indicate a 10 pinion as WH figured it needed better lubrication in the gear drive trannies. 2 2 Share this post Link to post Share on other sites
Maxwell-8 4,366 #3 Posted December 23, 2024 (edited) Seems like it doesn't have it, thanks for the tip. Nevertheless, it will be a good addition to the herd. Will post a picture when I pick it up this Friday. Edit: After some research on the forum. I found there are two variants of the 10pinions transmissions: the 5060 (having the extension) and the 5071 used in the raider 10 en 12 in 1969 (not having the extension) edit 2: Are all 6 speeds limited slip? Edited December 23, 2024 by Maxwell-8 1 Share this post Link to post Share on other sites
953 nut 57,833 #4 Posted December 24, 2024 All limited slip transaxles have 1 1/8" axles but not all transaxles with 1 1/8" are limited slip. All transaxles with 1" axles have an open differential. 1 hour ago, Maxwell-8 said: I found there are two variants of the 10pinions transmissions: the 5060 (having the extension) and the 5071 used in the raider 10 en 12 in 1969 The 5060 has aluminum end plates on the differential and the 5071 has steel end plates. 1 Share this post Link to post Share on other sites
Handy Don 13,340 #5 Posted December 24, 2024 2 hours ago, Maxwell-8 said: Seems like it doesn't have it, thanks for the tip. Nevertheless, it will be a good addition to the herd. Will post a picture when I pick it up this Friday. Edit: After some research on the forum. I found there are two variants of the 10pinions transmissions: the 5060 (having the extension) and the 5071 used in the raider 10 en 12 in 1969 (not having the extension) edit 2: Are all 6 speeds limited slip? The service manual for the transmissions seems to imply that both 5060 and 5071 had the extension--both would have needed the extra depth of gear oil since they are the same except for for the diff endplates that @953 nut noted. Quite a few threads here discussing what to expect (and not to expect) from LSD! Another potential indicator is to put the trans in neutral and jack up the rear end. Then manually slowly turn one rear wheel. If it’s an LSD in good condition, the opposite wheel will turn in the same direction instead of the opposite direction as it does for an open diff or a weak LSD. 2 Share this post Link to post Share on other sites
Lee1977 7,030 #6 Posted December 24, 2024 My 1971 Raider 12 has a limited slip a 6073. It doesn't have the pipe nipple on the left side. You model number should be centered under the dash. 1 Share this post Link to post Share on other sites
Handy Don 13,340 #7 Posted December 24, 2024 12 hours ago, Lee1977 said: My 1971 Raider 12 has a limited slip a 6073. It doesn't have the pipe nipple on the left side. You model number should be centered under the dash. The 5073 had a dipstick, right? The earlier models did not. 1 Share this post Link to post Share on other sites
Lee1977 7,030 #8 Posted December 24, 2024 1 minute ago, Handy Don said: The 5073 had a dipstick, right? The earlier models did not. No, It has a pipe nipple on top with a pipe cap. . Share this post Link to post Share on other sites
Handy Don 13,340 #9 Posted December 24, 2024 2 minutes ago, Lee1977 said: No, It has a pipe nipple on top with a pipe cap. I could easily be wrong, but I’ve never seen an unmodified UniDrive with a top opening that didn’t have a dipstick in it. Share this post Link to post Share on other sites
Lee1977 7,030 #10 Posted December 24, 2024 The "Toro Parts Drawings" is working again. I check the transmission parts list on my tractor (1-0310). It listed a no. 6155 Dipstick, a no. 1243 cup plug. a no. 943460 allen plug, and another 943420 plug. 1/2" close nipple, and a 1/2" pipe coupling. I got the tractor in Feb. 2023. and it has the plug and no dipstick. As Wheel Horse used what they had on hand other 71 models could have had the dipstick.. Mine has the 1/2 nipple and coupling with hex head plug. Share this post Link to post Share on other sites
Handy Don 13,340 #11 Posted December 24, 2024 10 minutes ago, Lee1977 said: The "Toro Parts Drawings" is working again. I check the transmission parts list on my tractor (1-0310). It listed a no. 6155 Dipstick, a no. 1243 cup plug. a no. 943460 allen plug, and another 943420 plug. 1/2" close nipple, and a 1/2" pipe coupling. I got the tractor in Feb. 2023. and it has the plug and no dipstick. As Wheel Horse used what they had on hand other 71 models could have had the dipstick.. Mine has the 1/2 nipple and coupling with hex head plug. Very cool that the parts list is alive again! Can you share the link you’re using? The ½ nipple, coupling, and plug are exactly what would be on the lower left rear side of the transaxle housing. These would assure that the proper, higher oil level was maintained when the plug was opened. The Allen plug is on the underside and used for draining, of course. The dipstick would be on top of the transaxle in the right rear area. I’m wondering about the 1243 cup plug, for sure! Share this post Link to post Share on other sites
Lee1977 7,030 #12 Posted December 24, 2024 (edited) Mine are on top, just a plug on the side. I'm using the "Redsquare Links" "The Toro Links" by nylyon -(Admin) May 26-2015 You'll have to get out of Christmas Theme, and I had to try a couple of times to get it to work. Edited December 24, 2024 by Lee1977 Share this post Link to post Share on other sites
stevasaurus 23,048 #13 Posted December 24, 2024 You can count on this...IF your brake drum is on the Mushroom Gear shaft, (the hole closest to the rear axle) and it is a 6 speed, then it is a 10 pinion Limited Slip transmission. It is either a 5060 or a 5071 and does not have a dip stick. The other Limited Slip transmission is the 5073. This one does have a dipstick and the brake drum is on the cluster gear shaft. The only exturnal way to tell if it is 8 or 10 pinions is to see if both wheels turn at the same time...put on ice with the front of the horse against a tree or post. The 8 pinion differential had 4 bolts holding the differentrial together, the 10 pinion differential has 5 bolts holding the differential together. One last thing, if you have 1" axles, it can be an 8 speed, but it only has a 4 pinion differential and is never a Limited Slip trans. 1 1 Share this post Link to post Share on other sites
kpinnc 13,702 #14 Posted December 24, 2024 (edited) 22 hours ago, Maxwell-8 said: Any way I can determine it has one without a tag number? If you can jack the rear wheels up, just spin one wheel. If the opposite turns the same direction, it's a 10 pinion. If it turns the opposite direction, it is not LSD. Edited December 24, 2024 by kpinnc 1 Share this post Link to post Share on other sites
953 nut 57,833 #15 Posted December 25, 2024 On 12/23/2024 at 8:11 PM, Handy Don said: Another potential indicator is to put the trans in neutral and jack up the rear end. Then manually slowly turn one rear wheel. If it’s an LSD in good condition, the opposite wheel will turn in the same direction instead of the opposite direction as it does for an open diff or a weak LSD. 4 hours ago, kpinnc said: If you can jack the rear wheels up, just spin one wheel. If the opposite turns the same direction, it's a 10 pinion. If it turns the opposite direction, it is not LSD 3 Share this post Link to post Share on other sites
Maxwell-8 4,366 #16 Posted December 25, 2024 Thanks everyone, I just have a couple pictures from the seller. I wasn't really looking into another tractor, but I will take the gamble hoping it is a limited slip. The Belgium tractors do not always have the same specs as the US made tractors. Going to pick up on Friday, I will renew my membership so I can post a couple pictures of it. 1 Share this post Link to post Share on other sites
kpinnc 13,702 #17 Posted December 25, 2024 13 hours ago, 953 nut said: Another potential indicator is to put the trans in neutral and jack up the rear end. Then manually slowly turn one rear wheel. If it’s an LSD in good condition, the opposite wheel will turn in the same direction instead of the opposite direction as it does for an open diff or a weak LSD I'm gonna blame the new colors and font for not seeing your post! 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #18 Posted December 27, 2024 (edited) The serial number is 1-301. 1972 with a Kohler K241S May this help? It has a solid brake drum, (no holes) on the front shaft inside the transmission, (so clustershaft?) It also has a 2inch high dipstick on top the transmission. edit; found it, I guess I lost, it's a 5086 transmission 8 speed 1" axles 4 pinions. Breakerless ignition on the k241 which is odd. And the diff part of the transmission is making a noise, So I will have to open it up. Edited December 27, 2024 by Maxwell-8 1 1 Share this post Link to post Share on other sites
stevasaurus 23,048 #19 Posted December 29, 2024 WOW !! I hate to say it but, I had a Raider 10 model #1-0301-7,,,serial# 863650 with a K-241S spec# 46636d that I sold to Skipper a few years ago in Denmark. It also had 1' axles trans #5086, 4 pinion differential. @Maxwell-8 do you suspect it might be my old tractor?? Check your numbers Mate. It was an excellent horse when I had it. 1 Share this post Link to post Share on other sites
Maxwell-8 4,366 #20 Posted December 29, 2024 1 hour ago, stevasaurus said: WOW !! I hate to say it but, I had a Raider 10 model #1-0301-7,,,serial# 863650 with a K-241S spec# 46636d that I sold to Skipper a few years ago in Denmark. It also had 1' axles trans #5086, 4 pinion differential. @Maxwell-8 do you suspect it might be my old tractor?? Check your numbers Mate. It was an excellent horse when I had it. I am sorry to disappoint you, but it is not your old tractor. . Mine is serial number 123888 made in Belgium. I am sure it will be a good tractor for me. It has the breaker less ignition which is odd. Definitely the way it is wired up by the PO. I was just hoping for a bit more diversity. I already have a raider 10. 4speed with a 4pinion diff. They are great on fuel, but our lawn is so wet the last few years. I am losing traction on turfs and don't want to go AG. It would even further destroy our lawn. 1 1 Share this post Link to post Share on other sites
Handy Don 13,340 #21 Posted December 29, 2024 3 minutes ago, Maxwell-8 said: don't want to go AG Other options include tires for ATVs that are “turf like” but vary from somewhat to extremely aggressive. Good luck! 1 1 Share this post Link to post Share on other sites
