Wheelhorse#1
PTO ELECTRICAL ISSUE
Wheelhorse#1
I recently wired my C-101 for a older K301 generator start engine. Its currently running and running as it should except when I engage the lever for the PTO bell, it shuts the engine down:huh:
The Original  PTO interlock  switch is still wired.The diagram I used didn't include a interlock switch.
 All other safety switches were deleted by the PO.
Anyone have any ideas what may be the issue here ? Thanks
Id like to keep the PTO wired in to prevent starting wile engaged .
pfrederi
Did you use a solenoid or did you use the heavy duty switch WH used on S/Gs?
squonk
I believe when you delete the seat switch, you have to connect the wires together to simulate a operator sitting on the seat and closing the switch. See if the seat wires are still connected. If they are not the engine would shut down when engaging the PTO
Wheelhorse#1
I used a Solenoid.
Wheelhorse#1
4 hours ago, squonk said:
I believe when you delete the seat switch, you have to connect the wires together to simulate operator sitting on the seat and closing the switch. See if the seat wires are still connected. If they are not the engine would shut down when engaging the PTO
I will check that out.
Thx
Edited by Wheelhorse#1
Wheelhorse#1
That was it Mike ! thanks again.Found the wires there but not connected.
You certainly know your stuff .
