Wheelhorse#1 1,761 #1 Posted December 23, 2024 I recently wired my C-101 for a older K301 generator start engine. Its currently running and running as it should except when I engage the lever for the PTO bell, it shuts the engine down The Original PTO interlock switch is still wired.The diagram I used didn't include a interlock switch. All other safety switches were deleted by the PO. Anyone have any ideas what may be the issue here ? Thanks Id like to keep the PTO wired in to prevent starting wile engaged . Share this post Link to post Share on other sites
pfrederi 18,322 #2 Posted December 23, 2024 Did you use a solenoid or did you use the heavy duty switch WH used on S/Gs? 1 Share this post Link to post Share on other sites
squonk 42,505 #3 Posted December 23, 2024 I believe when you delete the seat switch, you have to connect the wires together to simulate a operator sitting on the seat and closing the switch. See if the seat wires are still connected. If they are not the engine would shut down when engaging the PTO 3 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #4 Posted December 24, 2024 6 hours ago, pfrederi said: Did you use a solenoid or did you use the heavy duty switch WH used on S/Gs? I used a Solenoid. Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #5 Posted December 24, 2024 (edited) 4 hours ago, squonk said: I believe when you delete the seat switch, you have to connect the wires together to simulate operator sitting on the seat and closing the switch. See if the seat wires are still connected. If they are not the engine would shut down when engaging the PTO I will check that out. Thx Edited December 24, 2024 by Wheelhorse#1 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #6 Posted December 24, 2024 18 hours ago, squonk said: I believe when you delete the seat switch, you have to connect the wires together to simulate a operator sitting on the seat and closing the switch. See if the seat wires are still connected. If they are not the engine would shut down when engaging the PTO That was it Mike ! thanks again.Found the wires there but not connected. You certainly know your stuff . 2 Share this post Link to post Share on other sites
