Mickwhitt 4,953 #51 Posted September 22, 2019 Ok, a few hours later I now have one lump rather than many parts. Time to step back and review the books to see if I have done things properly. Not sure how to attach photos as yet so I will spend some time mastering that so I can share my progress. Regards Mick Share this post Link to post Share on other sites
Mickwhitt 4,953 #52 Posted September 22, 2019 Ok, a few hours later I now have one lump rather than many parts. Time to step back and review the books to see if I have done things properly. Not sure how to attach photos as yet so I will spend some time mastering that so I can share my progress. Regards Mick Share this post Link to post Share on other sites
Mickwhitt 4,953 #53 Posted September 22, 2019 I know it probably looks more like a before photo than after but I will do cosmetic work when its actually running lol Share this post Link to post Share on other sites
953 nut 57,402 #54 Posted September 18, 2021 In the event you are unsure about checking the condition of your balance gears, take a look. https://www.youtube.com/shorts/rMQy2qG25jc 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,758 #55 Posted January 26, 2023 I removed the balance gears from a K301 when I did a rebuild on it.It vibrates some but not to the point to were its bothersome.Higher rpms it smooths right out. Share this post Link to post Share on other sites
Rick3478 433 #56 Posted January 27, 2023 On 7/15/2016 at 8:06 PM, Short Circuit said: There are two axis of vibration in the engine (this is a simple version). The major axis is the vertical axis of the piston/rod assembly in the cylinder moving up and down as the crank rotates. This vibration is opposed or "countered" by the counter weights on the crank. In the gear head world, this is usually called primary vibration. On 7/15/2016 at 8:06 PM, Short Circuit said: The other "axis" of vibration is the lower end of the rod on the crank as it rotates around, and this vibration is "countered" by the balance gears, but only in a horizontal axis at 90 degrees to the crankshaft, in other words front to back on a Wheel Horse. On a JD, Cub, or other application where the crankshaft is pointing front to back, the balance gear axis is horizontally left to right (90 degrees to the crank). This is usually called secondary vibration. Thanks for good explanation @Short Circuit. I've been reading some of the old threads and just wanted to add a bit. Because they are not load bearing parts, it was deemed sufficient to manufacture the balance gears with a cheaper (and weaker) sintering process, rather than cast or forged. So, good enough for stock speeds, but if you spin 'em up bad things can happen, earning the grenade reputation. For what it's worth, Kohler isn't the only company to have done this, and not only on single cylinder engines. Father had a Dodge Aries with a four cylinder engine that included a pair of balance shafts geared to the crank. I won't go into the other shortcomings the car may have had, but the engine was smooth. Share this post Link to post Share on other sites
Pullstart 64,306 #57 Posted May 9, 2024 I made a video on balance gear removal. I figured I’d add it here to this discussion, just to show the details of what is to be done. With the K241 having a shorter stroke, I do believe the second gear can be removed without disturbing the pin. The K301, K321 and K341 will require crank removal or drive the pin out (in). I’ll also point out that the YouTube thumbnail generator was on point with the SNAP! picture. It’s funny, it indirectly had nothing to do with the gears blowing out a block wall . 1 1 Share this post Link to post Share on other sites
WHX?? 50,416 #58 Posted May 9, 2024 (edited) I watched @Achto take them out on a 321 without driving pins. I was just holding the flash lite when he was playing with his crank and it just kinda fell out... Edited May 9, 2024 by WHX?? 3 Share this post Link to post Share on other sites
Achto 28,534 #59 Posted May 9, 2024 (edited) 1 hour ago, WHX?? said: I was just holding the flash lite when he was playing with his crank and it just kinda fell out You just have to find the sweet spot, then the second gear will come right off. Did not have to drive any pins out. Edited May 9, 2024 by Achto 1 1 Share this post Link to post Share on other sites
953 nut 57,402 #61 Posted May 13, 2024 On 5/9/2024 at 8:38 AM, WHX?? said: just holding the flash lite when he was playing with his crank and it just kinda fell out... Jim, you do have a way with words! 1 3 Share this post Link to post Share on other sites
squonk 42,247 #62 Posted May 13, 2024 On 5/9/2024 at 8:38 AM, WHX?? said: I watched @Achto playing with his crank and it just kinda fell out... 1 3 Share this post Link to post Share on other sites
oliver2-44 10,216 #63 Posted May 13, 2024 The 2nd one come out easy with a quick rap on a sharp chisel. way easier that driving the pin out IMHO. Once the gears out you can easly removethe remaining snap ring. 2 Share this post Link to post Share on other sites
