ebinmaine
Kohler carburetor pictorial
OutdoorEnvy
Very nice process and great tutorial EB!  This will help a lot of folks :handgestures-thumbupright:
c100rider
Definitely helps me. Carb rebuilds is witchcraft to me.
  • Haha 2
ebinmaine
Understandable.  Patience is key.
Thanks....
I'm hoping....
squonk
Bowl nut always leaks. Old bowl , new bowl, new nut doesn't matter. I started using Permatex Aviation sealer on the new nut gasket. The new gaskets are plastic. The old ones are metal. The last carb I did I re used the metal gasket. It's for stock so I still don't know if it's going to leak or not.
ebinmaine
Keep us posted on the leakage when ya install that.
WHX??
1 hour ago, ebinmaine said:
Patience
What's that??
I have never taken out the welsh plug. Figured if you was supposed to there would be one in the kit.
Now you know why I sent you a box of carbs to play with ... :D
  • Haha 3
c100rider
Thanks....
I'm hoping....
I've done rebuilds before. Not too bad. My main problem is the screw mixtures. I don't have an ear for the tuning.
tunahead72
That's exceptional work, Eric, nicely done!
  • Thanks 2
Bar Nuthin
I swapped out my original carb for a Wuhan. At the time I decided a $20 carb would give time find a replacement needle. The PO must have torqued it down too hard and buggered the tip. The only needles I saw at the time were like $75.
I figured at some point I will refurbish it. But now I'm thinking I'd be better off mailing it to Eric! :D
Edited by Bar Nuthin
  • Haha 1
kpinnc
5 hours ago, ebinmaine said:
Thanks....
I'm hoping....
Absolutely beautiful! Makes me wanna ship you all of mine in the future! :bow-blue:
Only one thing I would add- I prefer brass screws on the butterflies. I had one come loose from the choke plate about a month after a rebuild. Made the most horrible sound you’ve ever heard in a Kohler. When I pulled the head, the screw was mashed flat. Had it been steel, I’m sure the piston and head would have been ruined.
Edited by kpinnc
  • Sad 1
ebinmaine
I understand your logic and quite frankly, using the steel screws bugs me for that very reason.
I switched to steel a few years ago for several reasons.
Brass screws were not readily available to me here.
Steel is a LOT easier for me to tighten properly.
I've read that Loctite bonds with steel better. (That may be hogwash)
Most importantly and most concerning to me. .... I've broken some brass screws while assembling.
ebinmaine
9 hours ago, WHX?? said:
What's that??
Your logic is sound there.....mostly.
The "kit" Kohler makes also doesn't include the gaskets for either end even though you should ALWAYS replace them.
I started removing the plug on EVERY carb fairly recently myself.
I'm glad I've done this because there's usually a bit of shmootz in that little cup.
ebinmaine
I can check to see if I have any extra needles. The long main one?
Ship it up. :handgestures-thumbupright:
953 nut
12 hours ago, ebinmaine said:
Also clean the tiny holes the feed fuel to the main bore. I use a tiny drill bit. Carefully.
I have been using torch tip cleaners for this, works well.          Hobart 770084 File Tip Cleaners, Small
squonk
So Eric, where are you getting the plugs from? I got a junk carb here I may yank the plug out and see how much shoogatzi is in there.
ebinmaine
I'll post a Pic later. It's a place called Mike's.... something... out in CA.
 shoogatzi
A technical term?
:lol:
Bar Nuthin
The long main one?
 Yes, sir!
leabassett@sbcglobal.net
Looks like new. Great job.
Oldskool
Looks brand new. Great tutorial.
I really should follow your process to rebuild one or two or ALL my carbs.
Thanks for posting this.
fourwheelhorseman
Man Eric, you’ve got this down to a science! Ive cleaned a lot of carbs in my day, but never to this level. The carb I got from Eric looks simply brand new and works like it is. Btw,  and maybe you’ve already revealed this before and I missed it, but what kind and size sonic cleaner do you have?
Edited by fourwheelhorseman
ebinmaine
Inexpensive one from Vevor.
Mine is a 3 Liter model with good old fashioned round manual knobs to set heat or time.
No digital anything.
I don't use the heater because I still use the lacquer thinner. I may switch to a less volatile fluid like pine sol. 🤔
I've stayed with lacquer thinner because I REALLY like the way it works to shine up the aluminum after some light wire brushing. And more importantly,  it doesn't have any negative effects on the main SEAT I always leave in the body.
Edited by ebinmaine
Fixing Bear silliness
tunahead72
6 minutes ago, ebinmaine said:
... I may switch to a less volatile fluid like pine sol. 🤔 ...
I've stayed with lacquer thinner because ... it doesn't have any negative effects on the main needle I always leave in the body.
I'll be interested in hearing your thoughts on pine sol as a carb cleaner when you get to it.  I used to follow a motorcycle forum that included a group of guys who used it regularly and swore by it.  And just now I did a quick search and realized there's a group on this forum as well.
Also, are you talking about the long mixture adjustment needle, and if so why do you leave it in the body for cleaning (your photos show it removed)? :confusion-shrug:
midpack
I've used Simple Green in mine. There's an aircraft version but I haven't used it on carbs
ebinmaine
I messed up that sentence.
I meant main SEAT.
I'll go fix it.
