Alrashid2
Thank You
SylvanLakeWH
Here's the link to become a supporter:
https://www.wheelhorseforum.com/store/
This place is amazing... a lot of knowledge, interspersed with some fun... :ph34r:
  • Heart 2
ebinmaine
@Alrashid2
Your name looks great in RED!
  • Excellent 2
  • Haha 1
Alrashid2
Ha! Just saw that now - I'm official!
$20 for all this knowledge? More worthwhile than college!!
  • Heart 5
SylvanLakeWH
That is an understatement... :handgestures-thumbupright:
  • Haha 2
rmaynard
Your questions helped many others without you knowing it. Thanks for becoming a support member. It's worth the $20.
And when I saw the picture you just posted, I thought I was looking at my own back yard. Will post a picture as soon as the sun comes out.
Edited by rmaynard
  • Like 5
  • Heart 1
Bar Nuthin
 Wow!
peter lena
@Alrashid2 noticing your oiled patina plow blade front , that finish is like adding HP when plowing , with snow release , been doing that for years , also noting the plow blade  wear edge , yours appears to be right in the middle , rotate that regularly , for wear , pavement plowing really takes a toll on that , so adjust to it , get some cross link rear chains , like an extension spring on mine , to follow chain tension , give it room to move , and it will always draw against  any looseness . also get after that plow quadrant  swing movement  set up , its simple , but  imperative  for functional ease , made a point of correcting  / eliminating  any repetitive  problem spot . track it down for function , and correct , like  wire cable wrap , and repositioning  original wiring  / chafing set up , stick on cable wrap mounts , tie wraps , gat a added fuel filter , close to carb bowl , stay at it , pete
Pullstart
Thanks for keeping the lights on @Alrashid2
  • Heart 1
Alrashid2
@rmaynard Wow that really does look like my property! Your deck is much nicer though! :)
@peter lena thanks for the advice! Yessir I did a few coats with pure motor oil. Love the patina look too!
