Maynardb 13 #1 Posted December 19, 2024 Hi does anyone know of a cheaper source for these axle seals? $30 each isn’t cheap but so far, I haven’t found any cheaper source thx Share this post Link to post Share on other sites
WHX?? 50,672 #2 Posted December 19, 2024 Only guy I know has them is Lowell and he gets 35 a piece. Yah little high for a lousy seal but wadda ya gonna do when they're not made anymore? Share this post Link to post Share on other sites
Bar Nuthin 935 #3 Posted December 19, 2024 (edited) You'll need to research the specifications, but I think this SKF seal may be the equivalent. Amazon.com: SKF 9815 LDS & Small Bore Seal, R Lip Code, HM14 Style, Inch, 1" Shaft Diameter, 1.25" Bore Diameter, 0.125" Width : Automotive Edited December 19, 2024 by Bar Nuthin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,240 #4 Posted December 19, 2024 The OD of the seal does not go into a bore. The OD is installed over the axle tube. Share this post Link to post Share on other sites
Racinbob 11,718 #5 Posted December 20, 2024 15 hours ago, Bar Nuthin said: You'll need to research the specifications, but I think this SKF seal may be the equivalent. Amazon.com: SKF 9815 LDS & Small Bore Seal, R Lip Code, HM14 Style, Inch, 1" Shaft Diameter, 1.25" Bore Diameter, 0.125" Width : Automotive The SKF 9815 is the 100863 for the two piece case 1"axle transmissions. 1 Share this post Link to post Share on other sites
WHX?? 50,672 #6 Posted December 20, 2024 19 hours ago, Bar Nuthin said: SKF seal may be the equivalent. Yeah nice try Bar but not the same seal. Back when I did my first two piece the 9815 could be had for 4 bucks and the 1257 was reasonable. Other ones are still affordable. Kinda the same thing with bearings. Me thinks seal manufactures are trying to capitalize on our addiction to horses ... 2 Share this post Link to post Share on other sites
Bar Nuthin 935 #7 Posted December 20, 2024 4 minutes ago, WHX?? said: Me thinks seal manufactures are trying to capitalize on our addiction to horses ... 1 Share this post Link to post Share on other sites
peter lena 9,084 #8 Posted December 20, 2024 @Maynardb https://defender.com/en_us/wpt-flax-packing-extractor-tool-size-0-10159?utm_id=146308134413&utm_campaign=19735474070&utm_source=google&utm_medium=paid&utm_content=649561297602&gad_source=1&gclid=CjwKCAiAyJS7BhBiEiwAyS9uNZD4APeKDxqysxqYODJoBs6JJiJU2mnXamEwfh_EfSPvpuRZek3kSRoCyCsQAvD_BwE packed hundreds of tank / vessel stuffing boxes , upper glass agitator area , make a tiny side seal hole , screw in , pull out . also like , SUPER LUBE as a rotational lubricant , multi spec for many applications , terrific in choke and throttle cables , check temp range , this lube is also excellent on jacket , plastic/ nylon zippers , effortless slide , pete Share this post Link to post Share on other sites
76c12091520h 3,784 #9 Posted December 21, 2024 These seals are still available from Toro. Pricey- yes, but it is the ONLY source for them. I keep them in stock at all times. If you have a local Toro dealer that has some in stock they may sell them cheaper if it's old inventory that they are looking to dispose of and the only people using this part # is those of us collecting them. 1 Share this post Link to post Share on other sites
