kpinnc 13,709 #1 Posted December 15, 2024 (edited) Anybody got a clutch with a legible decal on it? Just curious what is on there. I can’t make mine out… Edit: Sorry fellas, I wasn’t thinking. Below is a pic I borrowed from @pfrederi that at least shows the type of clutch I’m asking about. Edited December 15, 2024 by kpinnc Share this post Link to post Share on other sites
pfrederi 18,322 #2 Posted December 15, 2024 Bit out of focus Basically warms you warranty will be voided if you do not demount the clutch using a pusher bolt. 1 Share this post Link to post Share on other sites
kpinnc 13,709 #3 Posted December 21, 2024 Well I repacked the bearings, cleaned it up and did a little painting today. Maybe Sunday it will get installed… Thank you @WHX?? 1 Share this post Link to post Share on other sites
peter lena 9,085 #4 Posted December 21, 2024 @kpinnc just curious , what did you use in the bearings ? do not have any , wide bearing seal faces that I have not , carefully removed and cleaned out / re grease with 550 flash point grease , the other half of any rotational set up , is the RELATED , LEVERS / LINKAGE , hand off areas . since starting that years ago , I marvel at how easily , original movement areas , with some added detailing , move in smooth / easy silence . MANUAL PTO LEVER , PLOW SWING LINKAGE , ANY HARD TO USE SET UP , IS USUALLY JUST A DETAILING FIX AWAY . how about , choke and throttle cables , that sound like a hack saw blade on rusted metal ? what could you possibly do ? 3 IN 1 , PENETRANT , orange bottle , also SUPER LUBE IN BOTTLE , check temp range ! if you want to get really scary , add a small extension spring to the cable end , connection point , imagine a spring assist , to close , against it , more function ! every time you move it , its assisted ! as the rust runs out , it starts to get easier, how could that be ? easy to add a SMALL PREFORATED , spring pull point anywhere, purists are terrified , its up to you , pete Share this post Link to post Share on other sites
pfrederi 18,322 #5 Posted December 21, 2024 (edited) 7 hours ago, peter lena said: @kpinnc just curious , what did you use in the bearings ? do not have any , wide bearing seal faces that I have not , carefully removed and cleaned out / re grease with 550 flash point grease , the other half of any rotational set up , is the RELATED , LEVERS / LINKAGE , hand off areas . since starting that years ago , I marvel at how easily , original movement areas , with some added detailing , move in smooth / easy silence . MANUAL PTO LEVER , PLOW SWING LINKAGE , ANY HARD TO USE SET UP , IS USUALLY JUST A DETAILING FIX AWAY . how about , choke and throttle cables , that sound like a hack saw blade on rusted metal ? what could you possibly do ? 3 IN 1 , PENETRANT , orange bottle , also SUPER LUBE IN BOTTLE , check temp range ! if you want to get really scary , add a small extension spring to the cable end , connection point , imagine a spring assist , to close , against it , more function ! every time you move it , its assisted ! as the rust runs out , it starts to get easier, how could that be ? easy to add a SMALL PREFORATED , spring pull point anywhere, purists are terrified , its up to you , pete This post is about an Electric PTO ether are no linkages etc that need lubrication... Edited December 21, 2024 by pfrederi 1 Share this post Link to post Share on other sites
kpinnc 13,709 #6 Posted December 21, 2024 7 hours ago, peter lena said: @kpinnc just curious , what did you use in the bearings ? I used regular red grease. Cleaned the bearings out with carb cleaner until nothing came out. It’s messy, but the bearings are very smooth afterwards. Then just carefully reinstalled the seals. New connectors will be here tomorrow. Hopefully I’ll get it installed then. 1 Share this post Link to post Share on other sites
pfrederi 18,322 #7 Posted December 22, 2024 They used two different inside bearing one had a longer inner race was yours the long race (left) or the more normal one (right)?? Share this post Link to post Share on other sites
kpinnc 13,709 #8 Posted December 22, 2024 6 hours ago, pfrederi said: They used two different inside bearing one had a longer inner race was yours the long race (left) or the more normal one (right)?? I think mine looks more like the one on the right. The race is flush on both sides. 1 Share this post Link to post Share on other sites
