WHX?? 50,696 #26 Posted December 15, 2024 21 hours ago, ebinmaine said: Them're neat. I gotta get mine set up on a tractor. Wished I could get mine to work better. I think it needs a special muffler so the tank doesn't get pressurized by the back pressure. 11 hours ago, 953 nut said: it isn't ignorance I plead the fifth ... 11 hours ago, squonk said: That's character! Well Squonky finally got something right ... 3 Share this post Link to post Share on other sites
Retired Wrencher 5,634 #27 Posted December 15, 2024 (edited) Eric to all of this post would have been nice if the kept production numbers. This would have help us to not give out the wrong info. Also this would of nailed down the so called this is a rare one. Edited December 15, 2024 by Retired Wrencher 1 Share this post Link to post Share on other sites
Racinbob 11,718 #28 Posted December 15, 2024 On 12/13/2024 at 9:46 PM, WHX?? said: This guy says rusty??? He's on crack thats PATINA!!!! Prolly doesn't know what a Blitz Fogger or character is either. See the two 1/4-20 bolts in the hood? Guess what I had mounted there. It was only 1 or 2 years old at the time. 3 Share this post Link to post Share on other sites
squonk 42,505 #29 Posted December 15, 2024 Blitz fogger holes on HHHOOOWWWAAARRRDDD!!! Remnants of the exhaust hook up. ( since rotted off) 3 Share this post Link to post Share on other sites
ebinmaine 70,672 #30 Posted December 15, 2024 11 hours ago, WHX?? said: Wished I could get mine to work better. I think it needs a special muffler so the tank doesn't get pressurized by the back pressure. I'd be interested to know the correct connection pieces too. The way I understand it, the Blitz feed holes would allow a drip which was then vaporized by the exhaust exiting the system. @squonk or @Racinbob maybe any thoughts? Share this post Link to post Share on other sites
squonk 42,505 #31 Posted December 15, 2024 (edited) I think it worked similar to a carb. The exhaust passing thru the pipe would leave a vacuum pulse behind it. (Venturi effect) Drawing the skeeter juice out of the can along with a little help from gravity. The Venturi effect is a phenomenon where a fluid's pressure decreases when it flows through a constricted area, causing its velocity to increase; essentially, as a fluid speeds up in a narrower space, its pressure drops, based on the principle of conservation of energy and is directly related to Bernoulli's principle Edited December 15, 2024 by squonk 1 1 Share this post Link to post Share on other sites
ebinmaine 70,672 #32 Posted December 15, 2024 6 minutes ago, squonk said: I think it worked similar to a carb. The exhaust passing thru the pipe would leave a vacuum pulse behind it. (Venturi effect) Drawing the skeeter juice out of the can along with a little help from gravity That's the impression I was under. The "bung" fitting going into the exhaust pipe must have been a pretty small opening. 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,494 #33 Posted December 15, 2024 Amazing really to think of using one of those with pesticides or herbicides... Makes me think: NOS Blitz Fogger attire available. Found in closets of long-dead WH Blitz Fogger owners everywhere who didn't use them... 4 1 Share this post Link to post Share on other sites
ebinmaine 70,672 #34 Posted December 15, 2024 @SylvanLakeWH I like that it's red. Proves it's actually Wheelhorse NOS product. 1 Share this post Link to post Share on other sites
953 nut 57,839 #35 Posted December 16, 2024 Fogger Shmogger, who needs a fogger! During World War Two the barrier islands off of Fort Pierce FL were training bases for the US Navy Under Water Demolition Teams (now SEALs) and the US Army Rangers. The mosquitos were everywhere and each tent had a vat of DDT right outsider. The men would slather DDT over every inch of exposed skin. Many of these men made Fort Pierce their home after the war and loved telling about all of their exploits during training. 2 Share this post Link to post Share on other sites
WHX?? 50,696 #36 Posted December 16, 2024 22 minutes ago, 953 nut said: Fogger Shmogger, who needs a fogger You sir have never been to the Portage Show. Skeeters thicker than the here. The fogger drips into the muffler with the drip rate controlled by a needle valve. Thinkin there needs to be a elbow or device inside the muff that creates a slight vacuum. Anybody have a copy of the OM sure would like to see it. Wonder what was provided with one to make it work. 2 Share this post Link to post Share on other sites
