Brockport Bill 1,822 #1 Posted December 11, 2024 Came across this tube in a misc parts pile -- it's part number # 119030 per a PartsTree sticker label on it -- it's identified as a "Crank support" - apparently to hold a Snowblower crank rod handle -- however, the part number shows N/A and therefore I can't find a cross reference to what model blower it would go to?? It isn't the same angle design of a blower I would recognize ?? Any ideas what blower this would go to ? Thanks, Bill 1 Share this post Link to post Share on other sites
ebinmaine 70,657 #2 Posted December 11, 2024 Does the flag fit in the end of that piece? Share this post Link to post Share on other sites
Pullstart 64,464 #3 Posted December 11, 2024 The bottom lift arm is usually straight EB. No bend in the middle. 1 Share this post Link to post Share on other sites
ebinmaine 70,657 #4 Posted December 11, 2024 10 minutes ago, Pullstart said: The bottom lift arm is usually straight EB. No bend in the middle. I had a single stage here for a little while that had a bend in the arm. Can't say for sure it was quite that steep. @Maz91 has it now. 1 Share this post Link to post Share on other sites
ebinmaine 70,657 #5 Posted December 11, 2024 Wondering if maybe this piece is the one that stands up off the side of the frame on a two-stage? Share this post Link to post Share on other sites
wallfish 17,484 #6 Posted December 11, 2024 (edited) 2 stage blower. There is a short solid rod on the blower frame in which that rod pins on to. Edited December 11, 2024 by wallfish 2 1 Share this post Link to post Share on other sites
PWL216 940 #7 Posted December 11, 2024 Hi @Brockport Bill here is a pic of that part and where it goes…. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #8 Posted December 11, 2024 What model of tractor is that? Not our long frame model snowthrower. Share this post Link to post Share on other sites
Brockport Bill 1,822 #9 Posted December 11, 2024 1 hour ago, PWL216 said: Hi @Brockport Bill here is a pic of that part and where it goes…. thanks - - what blower model name and number is that? I can't tell from that rear view??? Bill Share this post Link to post Share on other sites
Brockport Bill 1,822 #10 Posted December 11, 2024 6 hours ago, ebinmaine said: Does the flag fit in the end of that piece? no flag does not go in that tube 1 Share this post Link to post Share on other sites
ebinmaine 70,657 #11 Posted December 11, 2024 1 hour ago, gwest_ca said: What model of tractor is that? Not our long frame model snowthrower. 41 minutes ago, Brockport Bill said: thanks - - what blower model name and number is that? I can't tell from that rear view??? Bill @PWL216 Is that the snow blower I now have? Share this post Link to post Share on other sites
Brockport Bill 1,822 #12 Posted December 11, 2024 6 hours ago, ebinmaine said: @PWL216 Is that the snow blower I now have? whatever the blower is in PWL216 photo that has the tube arm supporting the crank is what i am asking for the blower model description and # thanks Share this post Link to post Share on other sites
Brockport Bill 1,822 #13 Posted December 12, 2024 On 12/11/2024 at 9:25 AM, PWL216 said: Hi @Brockport Bill here is a pic of that part and where it goes…. i came aross this FB post and the side angle photo appears to be a 2 stage wh blower with that tube crank support that looks like the one i have? Yes/no? 1 Share this post Link to post Share on other sites
ebinmaine 70,657 #14 Posted December 12, 2024 2 hours ago, Brockport Bill said: i came aross this FB post and the side angle photo appears to be a 2 stage wh blower with that tube crank support that looks like the one i have? Yes/no? I'd say that's true. I have those parts at home. I can get you pictures and measurements sometime in the next couple days to confirm. Share this post Link to post Share on other sites
Brockport Bill 1,822 #15 Posted December 12, 2024 6 minutes ago, ebinmaine said: I'd say that's true. I have those parts at home. I can get you pictures and measurements sometime in the next couple days to confirm. excellent -- thanks Share this post Link to post Share on other sites
Brockport Bill 1,822 #16 Posted December 12, 2024 2 hours ago, ebinmaine said: I'd say that's true. I have those parts at home. I can get you pictures and measurements sometime in the next couple days to confirm. Eric -- witht the clues you and others provided, i just found the info on that blower crank support tube - went to the Interchange list to research models of blowers -- then to the various diagrams on partstree - - so i won't need you to research -- so THANKS FOR OFFER -- in fact, tube is for 2 stage blower models 06-44sc01 and successor model # 79361 -- it is the crank support tube. Appreciate your offer to research !! as an fyi -- its N/A any longer. Bill 1 Share this post Link to post Share on other sites
