Brockport Bill 2,122 #1 Posted December 11, 2024 came across this part among other loose parts ( see photos ). I'm guessing it's a Snow Blower 'flag" - - does anyone know the blower model, or model #, or description, this may go to? OR.... if it's some other part, what it may be? Thanks, Bill Share this post Link to post Share on other sites
wallfish 18,781 #2 Posted December 11, 2024 @stevebo needs that part for his 2 stage blower which fits on the Xi series tractors. It's unique to those particular blowers. He could also use that chute handle support you posted in another thread. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,600 #3 Posted December 11, 2024 Bill, interested if you wish to sell. Thanks Share this post Link to post Share on other sites
Brockport Bill 2,122 #4 Posted December 11, 2024 9 hours ago, stevebo said: Bill, interested if you wish to sell. Thanks was not sure what i was going to do with it --- yes, i would sell it - - first trying to identify its model it goes to ? I don't have a blower and my grandson's blower ( # 79360 ) is not a fit ? i also have the chute control turn crank rod that i see on partstree and toro site ( #51-2650 ) retail at approx $200 -- yikes !! also have that black plastic handle cover ( 40-8230 ) for the crank Share this post Link to post Share on other sites
Gravely Horse 19 #5 Posted December 12, 2024 If the rod is 3/4” diameter it’s for a 79365 42” single stage, if it’s 1” diameter it’ll fit stevebo’s 79366 44” two stage. Since it’s bent it’s probably for the 79366. Don’t know if they are supposed to be, but almost every one I’ve seen so far is bent. Share this post Link to post Share on other sites
Brockport Bill 2,122 #6 Posted December 12, 2024 41 minutes ago, Gravely Horse said: If the rod is 3/4” diameter it’s for a 79365 42” single stage, if it’s 1” diameter it’ll fit stevebo’s 79366 44” two stage. Since it’s bent it’s probably for the 79366. Don’t know if they are supposed to be, but almost every one I’ve seen so far is bent. the end of the "flag" rod ( which is solid material ) is 1 inch width -- however, the inside diameter I.D. of the tube crank support is 3/4 inch with a O.D. of 1 inch - hope that helps Bill Share this post Link to post Share on other sites
OoPEZoO 578 #7 Posted December 12, 2024 Those are definitely for the 2-stage thrower off of a 5xi. They are identical to what is sitting in my garage that I measured for Steve a few weeks ago. Share this post Link to post Share on other sites
Bar Nuthin 1,806 #8 Posted January 18 (edited) On 12/11/2024 at 6:31 PM, Brockport Bill said: delete Edited January 18 by Bar Nuthin delete Share this post Link to post Share on other sites
Cjwv1975 117 #9 Posted January 19 Wouldnt happen to still have chute control rod? Share this post Link to post Share on other sites
peter lena 9,552 #10 Posted January 19 @Cjwv1975 , get a 3/8 16 , die nut and thread the upper hand end , then get screw on knob at local H/W store , makes mitten / glove use easier , put those on my blowers , pete Share this post Link to post Share on other sites
Cjwv1975 117 #11 Posted January 19 2 minutes ago, peter lena said: @Cjwv1975 , get a 3/8 16 , die nut and thread the upper hand end , then get screw on knob at local H/W store , makes mitten / glove use easier , put those on my blowers , pete Any idea on length of rod. Would 4ft work? I mess around with it tomorrow but if i can get an idea on stuff I can stop at hardware store and buy rod. THANKS 1 Share this post Link to post Share on other sites
