Leland
"snow blower releases when locked in the raised up position
Leland
can anybody tell me why the snow blower when raised up in the locked position with the lever that it releases when moving and falls down  . Does not do it with the plow as the snow blower is heavier I assume.
Gasaholic
Probably worn out lift lever latch detent, or possibly weak button return spring. Can also be worn out rock shaft bushings, missing e-clip. First let implement down far enough so you can look at the detent notch on the side (Some machines have the notch inside the side panel, depends on you rmodel) and see if it appears to be hogged out and sloped , then take a look at the lift button detent rod end (L-shaped) and see if it looks bent or worn down, look for gunk keeping things from full travel, does the lift rod return fully when you press button down (can you pull it up further?) - that'd be indicative of worn or broken return spring.. (Oh yeah, also make sure the hand grip is fully seated on lift lever tube..)   Replacement of the detent rod/lift button involves removing the whole lift lever assembly and rockshaft (lot of side panels to remove) and disassembly.  Bushings (depending on which side) can be easy or difficult to replace. Does the lift arm rockshaft have a lot of side-to-side play (You'd pull off belt cover to check e-clip on that side anyways) they can also be shimmed for a bit tighter end play..
  • Excellent 2
ri702bill
What model tractor??
An assist spring may help to get a more neutral weight, but it is not a cure all for worn out lift lever parts.
Leland
312-8 and it does have the side to side play and I did take off the side cover but could not see any place to adjust it or even how to shim to go in further or should I say up. Also when it is all the way locked up the lever will move some front to back. the hand grip is all the way down. How would you bend the L shape latch ? The button return spring  = Is that under the hand grip?
Edited by Leland
ri702bill
Download the repair manual for your year tractor - I believe there were changes over the years.The exploded view will explain a lot....
Leland
ok thanks. is there a free manual as seems like have to pay to get one from wherever
Wayne0
You can get it here for free.
Leland
I do not see a link
ri702bill
Are you looking on the Browse Manuals section?? Upper left near the WH Icon.
Leland
ok got it thanks
peter lena
@Leland  those schematic  drawings are great at exposing long neglected , service areas . thanks  @gwest_ca  often refer to a problem / service area , as a gold mine for improvement , typical consul mount spot is easily exposed , with top 4 phillips head screws , knock r loose penetrant with extension tube will get the rust moving , regular stuff for me . that lever spring push point is a great start spot , also note rusty end point movement areas, make the rust run out , those bronze crosse consul  bushings , also need a  drink . while you are at it  3-1 small can penetrating oil , is great on / in saposed to be cabling, makes choke and throttle , cables work with out , dry scraping noise. regularly go after anything thats acting up /  change it / improve it , just the way I get after a repetitive  issue , pete
Leland
thanks for all the help and attached is a HOPEFULLY fix which took a while. If anything is rusty would have to be in the spring area on top  as this tractor has always been stored in a heated garage since I had it but our son did use it for a few years but stored it in a shed and no rust anywhere I can see actually looks like a little grees or spary oil around the L shaped rod where it latches in. . Now I cannot gurantee what I did in the picture will hold up and after many tries and errors ( mostly error) then a quick ride out the garage over a slight bump and down the road a little = So far so good.
