Rucan 2 #1 Posted December 7, 2024 My wheelhorse 441-8 has the electric lift. It often stops working with the snow plow stuck either in the up or down position. When I bring it in the garage and go back to it later then it will start working again. Never does it with the mower deck on in the summer. Share this post Link to post Share on other sites
kpinnc 13,710 #2 Posted December 7, 2024 (edited) Electric actuators have stop switches to prevent damage at the top and bottom of its travel. Sounds like yours isn’t completing the circuit. Edited December 7, 2024 by kpinnc Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #3 Posted December 7, 2024 15 page service bulletin may help 1 Share this post Link to post Share on other sites
Rucan 2 #4 Posted December 7, 2024 1 hour ago, kpinnc said: Electric actuators have stop switches to prevent damage at the top and bottom of its travel. Sounds like yours isn’t completing the circuit. Is that the clicking I'm hearing?? Share this post Link to post Share on other sites
kpinnc 13,710 #5 Posted December 7, 2024 2 minutes ago, Rucan said: Is that the clicking I'm hearing?? Likely the gear jumping past the threads on the worm drive. You probably should avoid that as much as you can. 2 Share this post Link to post Share on other sites
953 nut 57,839 #6 Posted December 8, 2024 15 hours ago, Rucan said: When I bring it in the garage and go back to it later then it will start working again. Never does it with the mower deck on in the summer. Take a close look at the housing, could be a crack that allowed some moisture to get in there and freeze up while out in the cold. Share this post Link to post Share on other sites
Rucan 2 #7 Posted December 8, 2024 (edited) 2 hours ago, 953 nut said: Take a close look at the housing, could be a crack that allowed some moisture to get in there and freeze up while out in the cold. Thank you. I have thought it may be weather related because it does not happen in the summer when it's warm Edited December 8, 2024 by Rucan 1 Share this post Link to post Share on other sites
