Glenn_K 3 #1 Posted December 7, 2024 Hello and thank you for accepting me to the forum. I've been using this Wheel Horse for a couple years to clear snow, it runs like a tank but a transmission issue just developed over the last few days. The part shown in the below picture (the part is just inside the left rear wheel) has been overheating very badly and creating a burning smell. This seems to only happen when i'm driving the tractor; it doesn't happen if the tractor is not moving w the PTO engaged. The transmission looks like it needs an oil change (the oil is milky looking). Could a transmission oil change be the solution or is the problem possibly something else? -- Glenn tractor hot spot.HEIC Share this post Link to post Share on other sites
Glenn_K 3 #2 Posted December 7, 2024 Inline picture of the overheating part Share this post Link to post Share on other sites
ri702bill 8,583 #3 Posted December 7, 2024 Glenn - Welcome!!. The oart shown is the brake assembly; the rotating drum and the fixed band. A mis-adjusted brake band will drag and create excess friction - and the burning smell. Share this post Link to post Share on other sites
Ed Kennell 39,290 #4 Posted December 7, 2024 (edited) to the As Bill said, the brake band probably needs adjusted or replaced. The milky transmission fluid indicates it contains water and should be changed ASAP. Edited December 7, 2024 by Ed Kennell wrong tranny 1 1 Share this post Link to post Share on other sites
oliver2-44 9,929 #5 Posted December 7, 2024 (edited) Be sure and change the transmission filter when you change the transmission oil. If your brake lining is worn you can ge a new one here. https://wheelhorsepartsandmore.com/product/brake-band-lining-wheel-horse/ From the looks of you brake I suspect the shaft seal behind it is leaking oil. It can be replaced from the outside if needed. yes an 8 Speed, so not filter. My Bad Edited December 8, 2024 by oliver2-44 Share this post Link to post Share on other sites
pfrederi 18,023 #6 Posted December 7, 2024 Isn't this an 8 speed???? Share this post Link to post Share on other sites
Ed Kennell 39,290 #7 Posted December 7, 2024 4 minutes ago, pfrederi said: Isn't this an 8 speed???? Oops, My bad. Share this post Link to post Share on other sites
Brockport Bill 1,749 #8 Posted December 7, 2024 milky tranny oil suggests either condensation inside or a bad shift handle boot and rain water getting in? Suggest you flush the tranny once first before you put in new oil - use kerosene or deisel for flush if its a gear tranny 3 Share this post Link to post Share on other sites
parsonsponyz 129 #9 Posted December 7, 2024 I agree with the brake band and changing transmission oil. Share this post Link to post Share on other sites
rmaynard 15,739 #10 Posted December 8, 2024 Brake lining special - Share this post Link to post Share on other sites
Lee1977 6,887 #11 Posted December 8, 2024 If the brake band is getting hot it is adjusted too tight need to be loosened up. It could need a new lining. The adjustment looser or tighter on the drum does not effect brakeing it only moves the placement of the brake pedal. It should be adjusted so it's loose enough to not get hot and that the parking brake still works. Too tight the parking brake won't lock in . Share this post Link to post Share on other sites
oliver2-44 9,929 #12 Posted December 8, 2024 When you drain the transmission oil jack the front of the tractor up as high as you safely can. The transmission has a hun in thee bottom center of it that prevents it from draining fully. 2 1 Share this post Link to post Share on other sites
Glenn_K 3 #13 Posted December 9, 2024 (edited) Thank you all for the warm welcome and for the information, as said, it was a brake issue -- the parking brake handle was stuck in a slightly engaged position and all that was needed was to unstick and then the tractor ran fine. There a small engine fixit guy in the family who is going to help me change the transmission oil. -- Glenn Edited December 9, 2024 by Glenn_K 3 Share this post Link to post Share on other sites
SylvanLakeWH 26,181 #14 Posted December 9, 2024 And Share this post Link to post Share on other sites
kpinnc 12,854 #15 Posted December 9, 2024 (edited) 7 hours ago, Glenn_K said: There a small engine fixit guy in the family who is going to help me change the transmission oil. It is a good idea to lift the front of the tractor (2-3 feet) to drain the tranny oil. There is a hump that traps dirty oil in the front of the tranny if you just drain it on flat ground. I just noticed @oliver2-44 beat me to the ”hump in the sump” explanation. Edited December 9, 2024 by kpinnc Share this post Link to post Share on other sites
953 nut 56,244 #16 Posted December 9, 2024 12 hours ago, Glenn_K said: the parking brake handle was stuck in a slightly engaged position and all that was needed was to unstick and then the tractor ran fine Glad it was a simple fix and you are back in the saddle again. Share this post Link to post Share on other sites
Tomato 19 #17 Posted January 11 Like Brockport Bill said, bad shifter boot can let moisture get inside rear end. Every trans I've gotten has had a bad boot and had moisture in transaxle. Share this post Link to post Share on other sites
