BuffaloD200
D-Series One Wheel Peel
BuffaloD200
Hey all,
My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
c-series don
One word: chains !!
  • Like 6
adsm08
I have studded chains and no weights or fluid in my tires. I get stuck only occasionally, and when I do grabbing a tread lug on the spinning wheel usually gets me moving. But I also have ag treads that I can grab like that.
Some WHs has limited slip, but not all. And even a limited slip is pretty useless if one wheel has no traction at all.
ebinmaine
This is my 1975 C160 Automatic.
I have four oversized tires all fluid filled.
There's 255 lbs of FLUID ALONE.
I also have another 130 lbs of steel weight in the rear.
There's also HD Ice Chains.
And the plow blade itself is a bunch of added weight. That's 60" wide and the edge is from a skidsteer.
With me on it this tractor weighs over 1400 lbs.
This is Trina's 867 Pigpen.
It has a 45 lbs weight out front. Snowblower front tires.
The rears are oversized and fluid filled with 7, 7.5 gallons each.
That's 160 + lbs of fluid.
She also has 130 lbs of steel and similar chains AND Limited Slip Differential.
BOTH of these tractors are nearly unstoppable within reasonable work limits.
  • Excellent 5
Ed Kennell
I prefer the rubber chains. They work best on the five paved driveways I plow and they don't leave any marks.  When plowing with the steel chains I find I can only plow downhill on the pavement.          I use the 2 link Vee Bar chains on ice and hard packed snow and on the stone roads that I plow.
Edited by Ed Kennell
  • Excellent 2
Lagersolut
1 hour ago, c-series don said:
One word: chains !!
This - my D-way is a slight hill - going down is easy - getting back up without chains won't happen - I use double link V bar ice chains with weight - if the weather starts out above freezing and wet , then goes cold,  the minute you push it and open up the wet - freezes turns to a sheet of ice - I keep bags of rock salt and ice melt here for after I'm done plowing/blowing .
1mor Project
Eb, I noticed you have your trip springs set to keep the blade vertical as it touches the ground. I keep mine on the top set of holes to help the snow dig in and roll off the blade better rather than loading up and lifting the plow. I have a long driveway, so rolling off the plow to the side makes it go a lot faster. I am still waiting for some snow here in Wisconsin to see how it works with my Raider 10 that I repowered with a 16 HP with a hydro pulley. It gives me a much better road gear.
I agree with the weights and chains. I prefer turf tires with 2 link chains with ice cleats, but I have both ag tires and 4 link chains on other tractors. Chains are needed no matter what tires you have.
ebinmaine
As you can see we have a gravel driveway. With the top holes the plow angle is such that it digs in to the soft parts WAY too aggressively.
This forward tilt we use keeps the gravel where it should be much longer.
We have no issues with the snow rolling off the sides. In fact, we have less trouble.
With the more forward angle we use the snow is actually directed DOWN and OUT in the front of the plow.
With the plow in the top hole we see more tendency to allow the snow to bury the plow by running right up over the top.
There is NO tendency for the plow to float over the snow with my monster blade as it's so incredibly heavy.
If the snow is very hard packed sometimes Trina will hold her blade down in tension using the solid link.
ri702bill
Nice. Best done in a 2 link setup, as a 4 link leaves too much space that gives an awful bouncy ride - your innards will thank you!
ebinmaine
Absolutely agreed.
Both our snow tractors have the two link chains 🔗 ⛓️
I even have a set for the front of mine. Not quite enough room to install them past the spindles with the oversized tires.  Once I get around to installing the trailer spindles and 5 lug wheels they should work.
Pullstart
These chains give the biggest bumpiest ride I’ve ever experienced on a tractor!  I was so excited to run them around at the big show, in the midst of our excitement of getting it running, @Tractorhead assumed my kidneys would thank me a took them off :lol:  I made sure to stick ‘em back on for the maiden voyage :handgestures-thumbupright:  That was before the added steel weight.  Now I can barely move the tractor around my shop floor without it being under it’s own power!
Pullstart
If I did not read this already, tire width has a lot to do with this.  @BuffaloD200 your D series likely has 12” wide tires.  @ebinmaine’s girl BBT has 8” wide tires I think?  The ones in the video above are 6” wide.  All of that, considering contact patch on the ground, creates a PSI to the ground.  More PSI to the ground (not tire pressure) = more traction.
Check this video out, to help explain the difference.  The wide tire provides so much flotation, it sacrifices traction.
WHX??
Shouldn't be too long ..  lookin to get a blast up yer way. We had three inches in Vilas county.
Pullstart
they are saying 4-10” by Friday night for us.
BuffaloD200
Wow.  Thanks for the responses guys!
It seems to be a unanimous tire chains.  I've ordered up a set of 4 link with barbs.  If I find I need a 2 link, I'll just order the individual chains.
I do have 12" wide Ag tires on it now, and they spin just like that video.
We got about 2-3 feet dumped on us last weekend and she struggled.  Another 1-2 feet forecast this weekend.
Now I just need to get the snowthrower to work properly...until then it works pretty dang good as a plow!
adsm08
Barbs are the way to go.
Like I said, I have barbed chains, no weights, no fluid, and I basically have to be on ice with a good head of snow and no momentum to get stuck.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
