peter lena 9,074 #1 Posted December 1, 2024 just added 2 tennis balls on to my walker , retained original rubber bottom skids , for more grip to the inside of the tennis balls . very tough to cut into , basically cut a wide X on the top of each ball , leaving pie shaped still attached to ball, very light silicone grease , to help slide in original rubber grip , to inside of ball . then used black electrical tape to bind the upper flowered tennis balls on to the aluminum legs , like the slide ease on tarmac / cement , the rate I am gaining on movement , walking ease , this walker will be taking a long nap . understand this mod is common to increasing walker usage . going in this week , for initial dr check / status . bionic pete 4 1 Share this post Link to post Share on other sites
Ed Kennell 40,398 #2 Posted December 1, 2024 6 hours ago, peter lena said: Greasy bionic pete There I fixed it for you. 1 Share this post Link to post Share on other sites
