billythegoat
choke cables for briggs engine
billythegoat
Briggs Stratton engine model number 252417-0664-01. on a GT1100 Wheel Horse. Cable broke at the end, Any ideas where I can purchase another? Bill on Cape Cod Mass. Thanks
ebinmaine
@Docwheelhorse is our local Briggs guru.
Ed Kennell
If the Zee bend broke, the cable can be shortened and a new Zee bend made with a couple needle nose pliers.
Handy Don
Or, live large and buy an actual z-bend-maker plier!
If the break is at the choke or throttle control end, you’ll realistically be looking for the full part. Have you checked out our vendors in the Classified section at the top of the page?
Edited by Handy Don
billythegoat
Thanks for the advice.  I believe I might have sufficient room to create a new z-bend.
peter lena
@billythegoat  https://www.amazon.com/Super-Lube-60004-Lightweight-Translucent/dp/B01IU6I214/ref=asc_df_B01IU6I214?mcid=aa00da7f1e8d31af8b43be2cd9e21e8d&tag=hyprod-20&linkCode=df0&hvadid=693405927029&hvpos=&hvnetw=g&hvrand=6650553147840997675&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1024403&hvtargid=pla-644882315889&psc=1  regularly use this on all my  cabling , check  temp range , have also added , a light extension spring , to related linkage hole , ASSISTING , PULL TO CLOSE . ? why would you do that ? think about it , every time you move the cable lever , its on a lubricated , spring assist , no rusty / dragging resistance , just smooth easy function . have that on all my related cables , it works , pete
Wayne0
I had to do that on my throttle cable.
