stevebo-(Moderator) 8,397 #1 Posted November 30, 2024 All, Wondering what/if anyone has a 523 dxi or any other small diesel machine and what you do to keep motor warm in winter months? I guess I am looking for a generic block heater or similar. I do not have space to keep the machine in a heated space. Share this post Link to post Share on other sites
squonk 42,450 #2 Posted November 30, 2024 Kats magnetic block heater. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,541 #3 Posted November 30, 2024 I'm not personally familiar with the cooling system of these so take this for what it's worth. If you have a decent flat spot on the bottom of the engine there are stick on heaters that work well. Some magnetic. Some glued. If you have a coolant hose with space to cut into, a circulating fluid heater is good too. DO NOT use a dipstick heater. Most of the engines don't have enough depth in the oil pool to keep the heater itself regulated. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,234 #4 Posted November 30, 2024 Some heaters have loose magnets I suspect to allow for an uneven mounting surface. The magnets work well but being loose leave the actual heated surface not contacting the metal you want to heat so there is zero heat transfer. Got around that by gluing a block of wood to the back of the heater and using a bungy cord to draw the heater tight to the bottom of the engine. Way more heat if you can mount on the bottom of the engine. The wattage is not very high. 2 Share this post Link to post Share on other sites
squonk 42,450 #5 Posted November 30, 2024 I use 2 of the smaller Kats magnetic heaters on my Power King hydraulic tank (Tank is the uprights that hold the loader) and they work great. Share this post Link to post Share on other sites
Retired Wrencher 5,630 #6 Posted December 1, 2024 22 hours ago, squonk said: Kats magnetic block heater. Looks like a nice unit Mike. What did you get for snow this past week? 1 Share this post Link to post Share on other sites
squonk 42,450 #7 Posted December 1, 2024 Just now, Retired Wrencher said: Looks like a nice unit Mike. What did you get for snow this past week? We are far enough from the lake that we got only a few flurries. Need the North/ Northwest wind to get lake effect here off of Ontario. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,397 #8 Posted December 1, 2024 Mike, I picked up that heater from tractor supply and it fit onto the oil pan. Not sure it will not get dislodged but for now it is on the pan and plugged in! 1 Share this post Link to post Share on other sites
Retired Wrencher 5,630 #9 Posted December 1, 2024 6 hours ago, squonk said: We are far enough from the lake that we got only a few flurries. Need the North/ Northwest wind to get lake effect here off of Ontario. That is good. I know you got hammered a few years ago. I heard upper N.Y. Received 2’ to 4’ Wow. Share this post Link to post Share on other sites
