Surrey,UK  based 244/5
Toro 244-5 cutting deck required (UK)
Model 72060 3900105 : the cutting deck has rusted away, non-repairable alas, so I'm looking for replacement if anyone is dismantling . Thanks for help.
gwest_ca
Two blade deck or 3-blades?
78215 38" Side Discharge Mower
78216 38" Side Discharge Mower Can be equipped with Recycler Kit 79170
78230 42" Side Discharge Mower
Thanks for post. It's a 2 blade ,side discharge with 3 rubber balls for motion support
wh500special
I’m not 100% positive about this, but I am fairly sure the decks from the 260 series (successor to the 240) will fit.  That might open some options for you.
of course a friend with welding equipment opens virtually unlimited options as well…
Steve
Steve
Thank you for the advice, I'll seek out local welders to see if a replacement is possible to make.
Steve
Edited by Surrey,UK based 244/5
Duplication
