ebinmaine 70,496 #26 Posted November 30, 2024 8 hours ago, Easton Rich said: You would need square hood fender brackets with the rear gas tank because the 76 front tank was just a straight up and down bracket. Unless you want to make or modify one? Somewhere around here I have a fender bracket from a 77 C160-8 speed. I'm wondering if I used that bracket with the fender and tank from a 78 it'd be close. Then use spacers as needed like @Lee1977 suggests. Share this post Link to post Share on other sites
Lee1977 7,020 #27 Posted November 30, 2024 (edited) Extend the steering wheel shaft up, add larger tires on the 520 front axle and 25" on the rear and you will have a C-series twin to my 316-8. Can't go much bigger then the 25" with the 300 frame you'll hit the rear bar Edited November 30, 2024 by Lee1977 2 Share this post Link to post Share on other sites
Lee1977 7,020 #28 Posted November 30, 2024 (edited) Here is a couple more pictures of the 316. Iused a couple of pieces of 2" channel ( use what you have ) a couple of pieces of 3/4" pipe will workI have a little trouble reaching the clutct, your tall enough it may be an improvement. Edited November 30, 2024 by Lee1977 1 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #29 Posted November 30, 2024 On 11/28/2024 at 6:51 PM, 953 nut said: Here's a few of the possibilities... 518 frame from @Handy Don 312-8 parts rig from @PWL216 '78 C141 Automatic parts rig also from @PWL216 2 1 Share this post Link to post Share on other sites
Bar Nuthin 932 #30 Posted November 30, 2024 4 hours ago, ebinmaine said: '78 C141 Automatic parts rig also from @PWL216 I would say the saddle tank is a "must have" 2 Share this post Link to post Share on other sites
kpinnc 13,628 #31 Posted November 30, 2024 On 11/28/2024 at 10:37 AM, ebinmaine said: Fuel tank under the seat like the later models. Just curious Eb, what will go in the spot for the fuel tank on the C-series tower? Not questioning your idea at all. Just wondering what the need for the tank under the seat is. If you stick with the 8-speed, you’ll have to chop the rear of the tunnel off that bolts down to the tranny. Or possibly use a tower setup from a hydro that is already chopped off. 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #32 Posted November 30, 2024 2 minutes ago, kpinnc said: Just curious Eb, what will go in the spot for the fuel tank on the C-series tower? Not questioning your idea at all. Just wondering what the need for the tank under the seat is. If you stick with the 8-speed, you’ll have to chop the rear of the tunnel off that bolts down to the tranny. Or possibly use a tower setup from a hydro that is already chopped off. The ideas I'm tossing around are for the future build/rebuild/ restoration of the Wally Digger Backhoe as a whole. @wallfish John and I talked about it a bit back in September at @JCM Jim's Meet n Greet. The 300/400/500 chassis would be a direct bolt to bolt swap of the 1977 loader and John's awesome Backhoe. I have a personal preference for the sheet metal style of the 1977 and older tractors. Trina has a huge preference for them as well because the angled steering tower makes them easier to repair & maintain. The tilt forward seat of the 1976+ is a necessity for operation of the rear controlled Backhoe. I'd like to have the fuel tank in the back for several reasons. 1. So I don't have to tilt the hood with the loader in the way. 2. I already have a tilting seat so the rear tank would be convenient. 3. Extra fuel capacity. @Handy Don reminded me yesterday that I already have a 518 frame which has the extra holes for the Gear Reduction Steering pieces. 2 Share this post Link to post Share on other sites
kpinnc 13,628 #33 Posted November 30, 2024 1 hour ago, ebinmaine said: I'd like to have the fuel tank in the back for several reasons. 1. So I don't have to tilt the hood with the loader in the way. 2. I already have a tilting seat so the rear tank would be convenient. 3. Extra fuel capacity. Ok, I understand now. Again I wasn’t questioning your reasons, just trying to follow along. I look forward to the build! 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #34 Posted November 30, 2024 32 minutes ago, kpinnc said: Ok, I understand now. Again I wasn’t questioning your reasons, just trying to follow along. Oh no worries. I didn't figure. 1 Share this post Link to post Share on other sites
Thor27 832 #35 Posted December 1, 2024 As far as the magnum with the early sheetmetal, it will all be fine except the muffler. This is a 91 312h. 2 1 Share this post Link to post Share on other sites
kpinnc 13,628 #36 Posted December 1, 2024 (edited) 4 hours ago, Thor27 said: As far as the magnum with the early sheetmetal, it will all be fine except the muffler. There ya go. Easy to extend it and the brace out about an inch. Longer pipe nipple and a spacer for the brace. Edited December 1, 2024 by kpinnc 1 1 Share this post Link to post Share on other sites
Thor27 832 #37 Posted December 1, 2024 @kpinnc Brilliant, that would certainly work. 1 Share this post Link to post Share on other sites
kpinnc 13,628 #38 Posted December 1, 2024 56 minutes ago, Thor27 said: Brilliant, that would certainly work Did this on my Bronco. 4 Share this post Link to post Share on other sites
ebinmaine 70,496 #39 Posted December 1, 2024 @Thor27 & @kpinnc. That muffler issue can be solved with a fairly easy swap to a Gravely Style muffler too. I have 2 here that are facing down and forward. That keeps most of the fumes from the driver. Share this post Link to post Share on other sites
mrc 873 #40 Posted December 1, 2024 a stack is another option 1 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #41 Posted December 1, 2024 32 minutes ago, mrc said: a stack is another option And an excellent one! Share this post Link to post Share on other sites
Pullstart 64,412 #42 Posted December 1, 2024 Like @Thor27 and @kpinnc I enjoyed that style muffler as well on Stormy the 1056. That was one tractor I could always trust to get chores done, but haven’ much missed it like I figured I would. 4 Share this post Link to post Share on other sites
Easton Rich 466 #43 Posted December 1, 2024 You might be able to modify a twin kolher muffler? 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #44 Posted December 1, 2024 31 minutes ago, Easton Rich said: You might be able to modify a twin kolher muffler? Likely could but it's just as easy to install a Gravely Style muffler Share this post Link to post Share on other sites
Retired Wrencher 5,630 #46 Posted December 3, 2024 Eric what s the main intent of this build. Just because of the Magnum engine? A.Heavy duty wood haler? 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #47 Posted December 3, 2024 31 minutes ago, Retired Wrencher said: Eric what s the main intent of this build. Just because of the Magnum engine? A.Heavy duty wood haler? Gary scroll on up to post #32. Share this post Link to post Share on other sites
Retired Wrencher 5,630 #48 Posted December 4, 2024 On 11/30/2024 at 4:09 PM, ebinmaine said: The ideas I'm tossing around are for the future build/rebuild/ restoration of the Wally Digger Backhoe as a whole. @wallfish John and I talked about it a bit back in September at @JCM Jim's Meet n Greet. The 300/400/500 chassis would be a direct bolt to bolt swap of the 1977 loader and John's awesome Backhoe. I have a personal preference for the sheet metal style of the 1977 and older tractors. Trina has a huge preference for them as well because the angled steering tower makes them easier to repair & maintain. The tilt forward seat of the 1976+ is a necessity for operation of the rear controlled Backhoe. I'd like to have the fuel tank in the back for several reasons. 1. So I don't have to tilt the hood with the loader in the way. 2. I already have a tilting seat so the rear tank would be convenient. 3. Extra fuel capacity. @Handy Don reminded me yesterday that I already have a 518 frame which has the extra holes for the Gear Reduction Steering pieces. Ok Eric. I see now. I hope it turns ok good for you. Nothing like a thought or an idea turned in to real time project. 1 Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 21 #49 Posted December 17, 2024 On 11/29/2024 at 5:52 AM, ebinmaine said: Can you elaborate on that front gas tank mount? I figured on using the rear tank from the late 70s and just leaving the forward shelf empty. you could also make it so the smaler front tank was an auxilary maybe 1 Share this post Link to post Share on other sites
ebinmaine 70,496 #50 Posted December 17, 2024 1 hour ago, Vintage_Wheel_Horse_Lover said: you could also make it so the smaler front tank was an auxilary maybe I'd had that thought too. Sometimes redundancy is good. Sometimes extra capacity is good. Share this post Link to post Share on other sites
