ebinmaine
300/400 frame with mid 70s sheet metal?
ebinmaine
8 hours ago, Easton Rich said:
You would need square hood fender brackets with the rear gas tank because the 76 front tank was just a straight up and down bracket. Unless you want to make or modify one?
Somewhere around here I have a fender bracket from a 77 C160-8 speed.  I'm wondering if I used that bracket with the fender and tank from a 78 it'd be close. Then use spacers as needed like @Lee1977 suggests.
Lee1977
Extend the steering wheel shaft up, add larger tires on the 520 front axle and 25" on the rear and you will have a C-series twin to my 316-8.
Can't go much bigger then the 25" with the 300 frame you'll hit the rear bar
Edited by Lee1977
Lee1977
Here is a couple more pictures of the 316.
Iused a couple of pieces of 2" channel ( use what you have ) a couple of pieces of 3/4" pipe will workI have a little trouble reaching the clutct, your tall enough it may be an improvement.
Edited by Lee1977
ebinmaine
On 11/28/2024 at 6:51 PM, 953 nut said:
:wwp:
Here's a few of the possibilities...
518 frame from @Handy Don
312-8 parts rig from @PWL216
'78 C141 Automatic parts rig also from @PWL216
Bar Nuthin
I would say the saddle tank is a "must have"
kpinnc
On 11/28/2024 at 10:37 AM, ebinmaine said:
Fuel tank under the seat like the later models.
Just curious Eb, what will go in the spot for the fuel tank on the C-series tower?
Not questioning your idea at all. Just wondering what the need for the tank under the seat is. If you stick with the 8-speed, you’ll have to chop the rear of the tunnel off that bolts down to the tranny. Or possibly use a tower setup from a hydro that is already chopped off.
ebinmaine
The ideas I'm tossing around are for the future build/rebuild/ restoration of the Wally Digger Backhoe as a whole.
@wallfish John and I talked about it a bit back in September at @JCM Jim's Meet n Greet.
The 300/400/500 chassis would be a direct bolt to bolt swap of the 1977 loader and John's awesome Backhoe.
I have a personal preference for the sheet metal style of the 1977 and older tractors.
Trina has a huge preference for them as well because the angled steering tower makes them easier to repair & maintain.
The tilt forward seat of the 1976+  is a necessity for operation of the rear controlled Backhoe.
I'd like to have the fuel tank in the back for several reasons.
1. So I don't have to tilt the hood with the loader in the way.
2. I already have a tilting seat so the rear tank would be convenient.
3. Extra fuel capacity.
@Handy Don reminded me yesterday that I already have a 518 frame which has the extra holes for the Gear Reduction Steering pieces.
kpinnc
Ok, I understand now. Again I wasn’t questioning your reasons, just trying to follow along. I look forward to the build! :thumbs:
ebinmaine
32 minutes ago, kpinnc said:
Ok, I understand now. Again I wasn’t questioning your reasons, just trying to follow along.:thumbs:
Oh no worries.  I didn't figure.
Thor27
As far as the magnum with the early sheetmetal, it will all be fine except the muffler. This is a 91 312h.
20241130_164044.jpg.15a49826e20fd7a47d6f28bde870074b.jpg20241130_164057.jpg.fbc3f0f6e36b6e6d8e48458e4cb434cf.jpg
kpinnc
There ya go. Easy to extend it and the brace out about an inch. Longer pipe nipple and a spacer for the brace.
Edited by kpinnc
Thor27
@kpinnc Brilliant, that would certainly work.
kpinnc
Did this on my Bronco.
  • Excellent 4
ebinmaine
@Thor27 & @kpinnc
That muffler issue can be solved with a fairly easy swap to a Gravely Style muffler too.
I have 2 here that are facing down and forward. That keeps most of the fumes from the driver.
mrc
a stack is another option
ebinmaine
And an excellent one!
Pullstart
Like @Thor27 and @kpinnc I enjoyed that style muffler as well on Stormy the 1056.
That was one tractor I could always trust to get chores done, but haven’ much missed it like I figured I would.
  • Like 4
Easton Rich
You might be able to modify a twin kolher muffler?
ebinmaine
Likely could but it's just as easy to install a Gravely Style muffler
Easton Rich
True
Retired Wrencher
Eric what s the main intent of this build. Just because of the Magnum engine? A.Heavy duty wood haler?
ebinmaine
Gary scroll on up to post #32.
:handgestures-thumbupright:
Retired Wrencher
Ok Eric. I see now. I hope it turns ok good for you. Nothing like a thought or an idea turned in to real time project.
Vintage_Wheel_Horse_Lover
On 11/29/2024 at 5:52 AM, ebinmaine said:
Can you elaborate on that front gas tank mount?
I figured on using the rear tank from the late 70s and just leaving the forward shelf empty.
you could also make it so the smaler front tank was an auxilary maybe
ebinmaine
I'd had that thought too. Sometimes redundancy is good. Sometimes extra capacity is good.
