ohiofarmer 3,383 #1 Posted November 25, 2024 20This is a marketplace find. There is a couple of guys who specialize in tongue and groove spruce boards and also pick up auction finds on occasion. They had several of these but this one was saved back for the owner. As they sell out very quickly he let me have this one he was saving for himself. It's rated for 660 pounds and lifts 65" The safety block is about nine inches shorter than that. The table top is 40x 20.5 All kinds of greasable fittings. The wheels are cast iron and coated with Plastic. She's nice and tight with paint in good shape. I sure wish I could find out the model and parts like the hydraulic pump. The plate with the specs had only ink applied and when I touched it to clean it up,the stuff was about gone. I plan to make a larger cover table so I can pull a tractor cross ways on it to lift it up. I have been a strong proponent for the Harbor Freight High position motor cycle lift which has been recalled. I will continue to use the three I have , but for other things. If anyone has taken my advice about the HFT lift and wants out, returning the hydraulic jack to HFT will result in your refund. I have seen a big variation of pricing on these lifts from Amazon to Northern Hydraulics. Mine was very reasonable even when compared to the lower fier pricing I will be back once the table build is complete. 4 4 Share this post Link to post Share on other sites
squonk 44,860 #2 Posted November 25, 2024 857 on my HF table lift. Had this thing close to 15 years and use it a lot! I also have the HF motorcycle lift that a PO retrofitted an air operated jack. 3 Share this post Link to post Share on other sites
ohiofarmer 3,383 #3 Posted November 25, 2024 (edited) This is the recalled lift. It's name was High Position Motorcycle Lift. Harbor Freight never displayed these in the showroom,but they were stocked in the back room. Never did I intend to put the regular HFT lift table down . The problem with my lift is that uneven loads could twist and break the welds. Thus the recall. My big lift table is a 36x96 lift table from South Worth made in the Eastern US. Rated at one ton and bought all beat up grom industrial salvage . I still love these little lifts. They are rated to eleven hundred, but the most I feel ok with is maybe 750 Edited November 25, 2024 by ohiofarmer 3 Share this post Link to post Share on other sites
