ebinmaine 67,474 #1 Posted 12 hours ago I got this rolling chassis from @PWL216 to use the parts for changing our own "Ugly Bruce" C121 over to Hydro lift. We believe the transmission should be good so I'd like to set it aside in case we need it. What's the best way to store a Hydro for the long term? @daveoman1966. @pfrederi @953 nut Share this post Link to post Share on other sites
Pullstart 62,851 #2 Posted 11 hours ago Good question! I think they generally just get the key turned off and left for a long long time. It would be interesting to know if there is a long term storage procedure… 2 Share this post Link to post Share on other sites
rmaynard 15,456 #3 Posted 11 hours ago By long term, how long are we talking? As far as I know, ATF or motor oil can sit on a shelf for decades without any problem. I don't see why sitting in a transmission would be much different. The 875 that I bought in 2019 had been sitting in the owners garage for almost 10 years without being used. Everything was fine when we started and drove it unto my trailer. I didn't change the fluids for several months. 4 Share this post Link to post Share on other sites
Ed Kennell 38,170 #4 Posted 10 hours ago May be a good idea to spin it once a month. Could be done with a drill on the input pulley. 2 Share this post Link to post Share on other sites
squonk 41,100 #5 Posted 10 hours ago Depends on where you leave it. Make sure there is no water in it at all. Maybe change the oil. If it's outside wrap it up the best you can. If it's indoors, put it where you can't fall on it or stub your tootsies on it. 1 Share this post Link to post Share on other sites
wallfish 16,996 #6 Posted 10 hours ago Store it in a place that you won't trip over it and you should be good for the long term. LOL If a tractor can sit outside in a field for 20 + years and then get fired up and drive without much trouble, I'd assume there really isn't much to it. You're going to need to go over it all when it finally comes out of storage anyway. 1 1 Share this post Link to post Share on other sites
pfrederi 17,739 #7 Posted 10 hours ago Sustrand hydros have a lot of fluid in the transaxle very little space for air. That means condensation from temp change is not a big issue. Even old Sunny's when you open the transaxle never see any rust like you would in a gear drive... 3 1 Share this post Link to post Share on other sites
squonk 41,100 #8 Posted 10 hours ago @wallfish and I agree on not going all @Pullstart and getting hurt having it laying around! 5 Share this post Link to post Share on other sites
ebinmaine 67,474 #9 Posted 10 hours ago 43 minutes ago, rmaynard said: By long term, how long are we talking? Best answer I can give there is, undetermined. I'd hope for never needing it. 43 minutes ago, rmaynard said: motor oil can sit on a shelf for decades without any problem. I've always thought the same until recent research has shown different. My current understanding is that there's 3 parts to an oil for use in an engine. 1. The base oil(s). These don't expire or go bad. 2. The Additive Package. Anti wear or detergent chemicals. These CAN fall out of suspension, but not always. 3. Anti Foaming Agents. These DO fall out of the oil within 3 to 5 years rendering it NOT USABLE in an engine. DO NOT USE ANY OIL IN AN ENGINE YOU CARE ABOUT THATS OVER 5 YEARS SHELF LIFE. Now, that said.... this is a hydro pump & transmission. Obviously not an engine. I don't know if the Anti Foaming Agents matter to operation at all but I'd imagine they help. Share this post Link to post Share on other sites
squonk 41,100 #10 Posted 10 hours ago (edited) 1 minute ago, ebinmaine said: Best answer I can give there is, undetermined. I'd hope for never needing it. I've always thought the same until recent research has shown different. My current understanding is that there's 3 parts to an oil for use in an engine. 1. The base oil(s). These don't expire or go bad. 2. The Additive Package. Anti wear or detergent chemicals. These CAN fall out of suspension, but not always. 3. Anti Foaming Agents. These DO fall out of the oil within 3 to 5 years rendering it NOT USABLE in an engine. DO NOT USE ANY OIL IN AN ENGINE YOU CARE ABOUT THATS OVER 5 YEARS SHELF LIFE. Now, that said.... this is a hydro pump & transmission. Obviously not an engine. I don't know if the Anti Foaming Agents matter to operation at all but I'd imagine they help. If yer use it yer gonna change the oil anyways unless yer cheap ! Edited 10 hours ago by squonk 1 Share this post Link to post Share on other sites
ebinmaine 67,474 #11 Posted 10 hours ago Just now, squonk said: If yer use it yer gonna change the oil anyways unless yer cheap ! Absolutely true Share this post Link to post Share on other sites
squonk 41,100 #12 Posted 10 hours ago Just now, ebinmaine said: Absolutely true Yer gonna change the oil or are yer cheap! (or both) 2 Share this post Link to post Share on other sites
ebinmaine 67,474 #13 Posted 9 hours ago 10 minutes ago, squonk said: Yer gonna change the oil or are yer cheap! (or both) Definitely both. 16 minutes ago, squonk said: put it where you can't ***** stub your tootsies on it. Hey what if I'm wearing my @Pullstart certified safety toed flip flops?? 1 Share this post Link to post Share on other sites
Lagersolut 661 #14 Posted 9 hours ago Something I learned many years ago when I picked up an old Troy built horse - long story short after purchase it leaked like a colander so I broke it down to repair and check bearings - after opening up the case it was apparent it sat for years unused - everything in the gear box not submerged in oil was rusted to pieces - the gears cleaned up fine but the input shaft was pitted at the seal engine pulley side - everything in the case had to come out . If somethings going to sit for an extended time turning it from time to time to coat the gears is a good idea - my restored C-101 is a non worker I get out and run around the yard 4-5 times a year to keep everything in the trans case wet 1 1 Share this post Link to post Share on other sites
squonk 41,100 #15 Posted 8 hours ago (edited) 3 hours ago, ebinmaine said: Definitely both. Hey what if I'm wearing my @Pullstart certified safety toed flip flops?? You will need shin guards as well! Edited 6 hours ago by squonk 1 Share this post Link to post Share on other sites
Pullstart 62,851 #16 Posted 8 hours ago I recently used an old quart of oil. Mainly to cut the bottle and use it as a funnel. This is what we found in the bottom. @ebinmaine mentioned additives settling out. 3 Share this post Link to post Share on other sites
squonk 41,100 #17 Posted 6 hours ago 2 hours ago, Pullstart said: I recently used an old quart of oil. Mainly to cut the bottle and use it as a funnel. This is what we found in the bottom. @ebinmaine mentioned additives settling out. Are those gloves or " elephant paws?" Share this post Link to post Share on other sites
rmaynard 15,456 #18 Posted 5 hours ago 3 hours ago, Lagersolut said: everything in the gear box not submerged in oil was rusted to pieces That confirms Paul's statement. Sustrand hydros have a lot of fluid in the transaxle very little space for air. That means condensation from temp change is not a big issue. Condensation in your Troy caused the rust. 3 Share this post Link to post Share on other sites
