Oldskool
Abrasive flap wheel. Install?
Oldskool
Hey guys I have been given a box of these flap wheels.
5.25" x 1.5" with a 1" arbor hole.
I instantly thought great I can put one on my bench grinder.
Nope!    Not that simple.
The arbor size is different, and it's to wide to fit inside the the guard.
I thought of removing the guard but would like to have it there.
I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
Does anyone use these, and if so what do you have it on?
John2189
4-1/2” angle grinder. They are great for sharpening lawnmower blades
953 nut
I have used them in place of a buffing wheel to remove rust and shape the edge of items that have encountered the use of a BFH Tool. I use them on a 3/4 HP Baldor polishing machine.
Baldor Buffer 3/4HP 2-Speed Bench-Mount
Wayne0
You'll have to bush the bore for your shaft size:hide: Remove the guard if it doesn't fit. I have a wire wheel I had to do that with.
Ed Kennell
I use the flap wheels and wire wheels on my guard free  extended  shaft grinder.   Much easier to work larger parts.
Oldskool
I do use one on my grinder. They are awesome.
These are a bit to big for that though.
Ed Kennell
I use these flap discs to sharpen blades, but neve a flap wheel.
Oldskool
Ya. That's what I need.
I bet not a cheap item.
Oldskool
I think that's what's gonna happen.
Oldskool
I use the disc for the angle grinder ALOT.
This box of 10 flap wheels were free so would love to use them.
That extended shaft grinder of yours is a beast. That would make me nervous.
I always seem to have a hood string from my sweatshirt dargling or a loose flap of clothes hanging.
953 nut
I've had the Baldor for about thirty years, took it in trade for doing some electrical work for a guy who had inherited it and had no use for it. Gotta watch for dangling hoody laces around anything that rotates.
@Ed Kennell, somehow I don't think your extended shaft grinder would pass OSHA inspection, they just don't know what a useful tool looks like.       :ychain:
Ed Kennell
For sure a big F on the OSHA test.        I do keep my first aid training and supplies updated.
Image result for duct tape bandage cartoons
  • Similar Content
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
