grinchsr
9-PIN Preservation
grinchsr
I was thinking of packing the connector with dielectric grease before I connect it together.  Good Idea or not?
johnnymag3
I wouldn't'.....its not just the connection that's the issue, its improper wire size in my opinion....Dielectric is great stuff..dont get me wrong, but 9 Pin Connectors need to be eliminated / converted.  JMO  :) Its a breeding ground for moisture and contaminants for those owners that never clean their machines, or power wash and never dry !!!
Again....JMOpinion    .02 cents worth
John.
Im sure others will chime in .........
jmo
953 nut
Using dielectric grease on any electrical connection is a good idea.
The nine pin connector was used by Onan for their convenience, not because it is the best connector available. The contacts were never adequate for high current loads and should never have been used on outdoor equipment.   :soapbox:
If the RED wire going to the battery from the fuse block and the WHITE wire from the voltage regulator were not run through the 9 pin connector it wouldn't be a problem. The other wires don't carry a great deal of current so the don't have a great likelihood of overheating. Over time with vibration and corrosion the contacts develop resistance to current flow and overheat.
My suggestion would be to remove the RED and WHITE wires from the 9 pin and splice them, white to white and red to red, with soldered connections.
Edited by 953 nut
add photo
squonk
 Despite the fact it has "electric" right there in the name, it's a fairly common misconception that dielectric grease is capable of conducting electricity. In actual fact, dielectric grease is an insulator and doesn't conduct electricity.
Use it to seal out moisture and cooties. do not go overboard.
  • Like 4
grinchsr
Thanks for all the answers
Racinbob
Perzactly. A definition of a capacitor is two conductors separated by a dielectric.
  • Excellent 2
