pfrederi 18,289 #1 Posted November 21, 2024 After overhauls or repair Kohler service manual and everyone here specifies re-torquing head bolts after warm up. Never heard it mentioned in the WH or Kohler User manuals anywhere about re-torquing on a new machine...wonder why that wasn't directed... 1 Share this post Link to post Share on other sites
ebinmaine 70,390 #2 Posted November 21, 2024 I've wondered the same thing. I've run it by friends that are technicians. I can't speak for the specific Sciences behind it. Hopefully somebody with a better understanding than me will pipe up. I've had discussions in both directions of yes it's always necessary or no you never need to do it. My thought process is, too many to similar materials for my comfort level are in play so I'm always going to retorque a cylinder head. In the case of a big block Kohler. The block is cast. The head bolts are steel. The cylinder head of course is aluminum. Some serious differences in the rates of expansion and contraction there. I've had the cylinder head off of maybe a dozen engines? I was probably two or three deep into that when I learned that they needed to be rechecked. When I go back and tighten up 10 bolts, one to three of them will move. 4 1 Share this post Link to post Share on other sites
Pullstart 64,388 #3 Posted November 21, 2024 On 11/21/2024 at 3:00 PM, ebinmaine said: My thought process is, too many to similar materials for my comfort level are in play so I'm always going to retorque a cylinder head. In the case of a big block Kohler. The block is cast. The head bolts are steel. The cylinder head of course is aluminum. Some serious differences in the rates of expansion and contraction there. *dissimilar materials* I agree. It’s worth doing! 2 Share this post Link to post Share on other sites
Fordiesel69 263 #4 Posted November 21, 2024 It depends on the head gasket used. If you re-use the old one, no you do not have to re-torque. If you use a brand new one, either OEM or aftermarket, you will absolutly need to retorque after some thermal cycles. 3 Share this post Link to post Share on other sites
ebinmaine 70,390 #5 Posted November 21, 2024 I know it's not the original discussion but I'd also like to add that replacing the cylinder head BOLTS probably does not get done often enough. None of the engines I've been into are less than 30 or 40 years old and I've started replacing the cylinder head bolts and washers on every single one of them. 5 Share this post Link to post Share on other sites
ri702bill 8,923 #6 Posted November 21, 2024 On 11/21/2024 at 3:00 PM, ebinmaine said: When I go back and tighten up 10 bolts, one to three of them will move. And there you have it folks. AND if it's the 2 closest to the exhaust port... guess what?? That is the most common spot for the gasket to fail, as that area see the greatest thermal swing in temperatures. The Kohler K Series Manual mentions to retorque as necessary - no number of times given. I take it that means until it holds torque on all bolts when cold. KohlerKseriesManual.pdfFetching info... 4 Share this post Link to post Share on other sites
Skwerl58 743 #7 Posted November 21, 2024 When I got my 1054 going,unstuck the exhaust valve, removed the head, cleaned it all up, smoothed it up and replaced the head. Torqued it down per specs and after running for a short while I retorqued it and was surprised how many bolts needed it. I then ran it again and retorqued and a couple bolts definitely needed it. I was surprised but rechecked because of post here on Red Square concerning doing it. It takes maybe 10- 15 minutes so why not? 2 Share this post Link to post Share on other sites
8ntruck 7,336 #8 Posted November 21, 2024 One does wonder what the proceedure at the Kohler factory was for torquing head bolts at initial engine assembly was. Maybe they did a test run on the engine, then retorqued the bolts? 1 Share this post Link to post Share on other sites
pfrederi 18,289 #9 Posted November 21, 2024 On 11/21/2024 at 4:03 PM, 8ntruck said: One does wonder what the proceedure at the Kohler factory was for torquing head bolts at initial engine assembly was. Maybe they did a test run on the engine, then retorqued the bolts? That was really my point. I do not think they test ran them and they are new head gaskets which might compress some... just puzzled 1 Share this post Link to post Share on other sites
squonk 42,363 #10 Posted November 21, 2024 Dissimilar metals. Expand and contract at different rates. Head gaskets shift. A 68 small block Chevy could run over 20 years on steel head gaskets with iron blocks and heads with no issues. An 82 K car with an aluminum head and iron block and composite gasket will pop it's cork within 5 years mostly from this movement. Aluminum wheels need to be retorqued after 50 miles of installation. Because of movement between the steel hub, lugs and nuts. I service a Jeep in upstate NY. Rotated the tires. Lady drove to Washington D.C. and halfway home a wheel became loose. They tried to blame me. Sorry. over 300 miles since I touched it and she never brought it in for a re torque. Big bold letters on the invoice: Aluminum wheels must be re-torqued within 50 miles! 1 Share this post Link to post Share on other sites
clueless 3,105 #11 Posted November 21, 2024 On 11/21/2024 at 8:23 PM, squonk said: Dissimilar metals. Expand and contract at different rates. Head gaskets shift. A 68 small block Chevy could run over 20 years on steel head gaskets with iron blocks and heads with no issues. An 82 K car with an aluminum head and iron block and composite gasket will pop it's cork within 5 years mostly from this movement. Aluminum wheels need to be retorqued after 50 miles of installation. Because of movement between the steel hub, lugs and nuts. I service a Jeep in upstate NY. Rotated the tires. Lady drove to Washington D.C. and halfway home a wheel became loose. They tried to blame me. Sorry. over 300 miles since I touched it and she never brought it in for a re torque. Big bold letters on the invoice: Aluminum wheels must be re-torqued within 50 miles! Did a K car ever make 5 years. 7 Share this post Link to post Share on other sites
Handy Don 13,266 #12 Posted November 21, 2024 (edited) On 11/21/2024 at 8:23 PM, squonk said: An 82 K car with an aluminum head and iron block and composite gasket will pop it's cork within 5 years mostly from this movement. I learned this when I asked why the head gasket on my Dodge Caravan failed. Car overheated badly and it was way beyond worth repairing the complete damage at that point but a preemptive head gasket replacement would have been a lot less and worth doing. Sigh, I liked that car, too! Edited November 21, 2024 by Handy Don 1 1 Share this post Link to post Share on other sites
8ntruck 7,336 #13 Posted November 21, 2024 On 11/21/2024 at 8:54 PM, clueless said: Did a K car ever make 5 years. There is a maroon K car wagon still roaming around Sedalia MO. See it a couple times per month. Share this post Link to post Share on other sites
ebinmaine 70,390 #14 Posted November 21, 2024 On 11/21/2024 at 8:54 PM, clueless said: Did a K car ever make 5 years. Given actual maintenance they would... The 2.2 Liter in particular was a pretty decent engine considering the times. Share this post Link to post Share on other sites
953 nut 57,581 #15 Posted November 22, 2024 On 11/21/2024 at 5:28 PM, pfrederi said: That was really my point. I do not think they test ran them and they are new head gaskets which might compress some... just puzzled Just out of curiosity I checked the head bolt torque on a Kohler Magnum 10 engine. The manual calls for 25 to 30 foot pounds, I started at 25, no movement, went to 30, still ne movement, change to 40, nothing. At 45 foot pounds a couple of the head bolts did move a bit, most didn't. My guess is the factory torques them to 45 knowing they are using new bolts and no owner is going to retorque them. When torqueing head bolts I lay this little memory aid on top of the head so I don't have to look up the sequence. 8 5 Share this post Link to post Share on other sites
WHX?? 50,560 #16 Posted November 22, 2024 On 11/22/2024 at 12:53 AM, 953 nut said: When torqueing head bolts I lay this little memory aid on top of the head so I don't have to look up the sequence Really good idea! 1 Share this post Link to post Share on other sites
pfrederi 18,289 #17 Posted November 22, 2024 On 11/22/2024 at 12:53 AM, 953 nut said: Just out of curiosity I checked the head bolt torque on a Kohler Magnum 10 engine. The manual calls for 25 to 30 foot pounds, I started at 25, no movement, went to 30, still ne movement, change to 40, nothing. At 45 foot pounds a couple of the head bolts did move a bit, most didn't. My guess is the factory torques them to 45 knowing they are using new bolts and no owner is going to retorque them. When torqueing head bolts I lay this little memory aid on top of the head so I don't have to look up the sequence. I was thinking that might be the case 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,758 #18 Posted November 27, 2024 On 11/22/2024 at 3:29 PM, WHX?? said: Really good idea! Great idea. I have been numbering the head bolts but wear off after a wile. Share this post Link to post Share on other sites
