Handy Don 12,197 #26 Posted 9 hours ago 9 minutes ago, squonk said: I love to see "Well Enjoyed" cement mixers bee-bopping down the Thruway at 70+MPH! It has long made me wonder why there isn’t a license “endorsement” for pulling a trailer along with a test like the one you took to get your license in the first place. The NY Boating Safety course (required to operate any motorized watercraft in NY) includes a nice chunk on loading and launching best practices. 1 Share this post Link to post Share on other sites
Achto 27,557 #27 Posted 8 hours ago @BillD One suggestion I will make when it comes to trailer construction, buying or building. Trailers that use a steel tube construction, these may seem like a good strong construction and they are. Here is the issue with them - There is no way to properly paint the inside of the tubing. They collect moisture through condensation, rain, etc. This causes them to rust from the inside out, so you often don't notice that it is happening until your frame breaks. How do I know this?? I had a flat bed utility trailer that used square tubing for the main frame construction. One day the frame broke right in front of one the spring shackles. A few taps on the out side with a pick hammer proved that the rest of the frame was not in sound shape either. I have also seen this issue multiple times with boat trailers that use a tube construction. The trailer that I built is made with 3" C-channel that has a 5/16" wall, all of the angle iron has 1/4" wall, and the tubing and angle for the tongue has 5/16" walls. Over kill??? Maybe, and it does weight 900lbs empty but I have no worries when it comes to frame failure. 2 1 1 Share this post Link to post Share on other sites
953 nut 55,152 #28 Posted 8 hours ago 4 hours ago, Achto said: More than likely. You can get larger home made trailers titled & register in WI but there are hoops to jump through, receipts to go through, and a state patrol inspection required My home made trailer I built in Florida only required an annual registration, no inspection, no title, not even a VIN. ( all about the $$$$) When I moved to NC and wanted to register it I was assigned a North Carolina VIN number which I was to stamp into the trailer tongue and some paperwork that needed to be signed by a NC Highway Patrolman. My little rural county doesn't have a NCHP station so I asked how this was to be done. I was told to tow the trailer around until I saw a NCHP car and flag them down. Spoke to a local policeman and he said just park it near the county courthouse any Monday since several NCHP officers would be there as trial witnesses. Sure enough, the first one I asked looked at the paperwork, asked if the NCVIN was on the tongue, I responded yes and he signed the paperwork without ever seeing the trailer. Got the title and lifetime registration for less than one year's FL registration. 1 Share this post Link to post Share on other sites
Ed Kennell 38,093 #29 Posted 7 hours ago 2 hours ago, ebinmaine said: Here in Maine. Easy. Is this why most of the semi trailers I see have Maine tags? Share this post Link to post Share on other sites
ebinmaine 67,376 #30 Posted 7 hours ago 6 minutes ago, Ed Kennell said: Is this why most of the semi trailers I see have Maine tags? Thats a different reason. Maine requires less or no inspection depending on class. Longer registered times. Average to lower initial fees. Semi trailers would be unlikely to be homemade. They'd be required to have safety inspections. At what interval I'm not sure. Trailers under 2K or maybe 3.5K registered weight and privately owned don't get inspections. 1 Share this post Link to post Share on other sites
kpinnc 11,957 #31 Posted 6 hours ago My only suggestion is to stay above 5 feet on the width. My trailer is 5x10, so nothing with a 60 inch deck will fit on it. Smaller round hoods will fit side by side, but only one if something like a C series or classic. I have transported two tractors but only by turning one sideways and wedging it between the rails. No fun getting it out… I wish my trailer was at least 6x12. I could trade up, but it’s hard to find another with a solid steel floor as I have now. It was home built and is much heavier built than trailers in its size range. 1 Share this post Link to post Share on other sites
Handy Don 12,197 #32 Posted 6 hours ago 1 minute ago, kpinnc said: stay above 5 feet on the width Depending on your tow vehicle, load capacity, total weight, and brakes also are a factor. I have had one round hood and one 312-H with a deck together on my un-braked 5x8. It was VERY tight and approaching the max capacity. Share this post Link to post Share on other sites
kpinnc 11,957 #33 Posted 6 hours ago (edited) 19 minutes ago, Handy Don said: Depending on your tow vehicle, load capacity, total weight, and brakes also are a factor. I have had one round hood and one 312-H with a deck together on my un-braked 5x8. It was VERY tight and approaching the max capacity. Good point. I sometimes forget plenty of people drive cars. My wife and I both have pickups so a trailer isn’t usually an issue. My truck is the smaller of the two (Tacoma V6), but still has no problem with 6000+lbs. I also have a trailer brake controller that is very helpful when it’s time to stop. The best trailer I ever pulled with my truck was a 7x14 Hudson with electric brakes. It was wide enough to see down both sides in the side mirrors, and handled very well. Edited 6 hours ago by kpinnc Share this post Link to post Share on other sites
ri702bill 8,301 #34 Posted 1 hour ago 7 hours ago, Handy Don said: includes a nice chunk on loading and launching best practices. Something to behold at the public Boat Ramp, for sure. If I go fishing with my SIL & Grandsons and there anything cold left to drink, we humor ourselves watching the actions (antics??) of other guys launching or loading. Some folks got it, some never will..... Share this post Link to post Share on other sites
