siebenaler 114 #1 Posted November 19, 2024 First off I'm in mn and looking for a deck for a Gt14 will any b or c series deck work? Share this post Link to post Share on other sites
953 nut 62,979 #2 Posted November 19, 2024 (edited) If you add a Mule Drive to the front of the GT-14 you can use any newer deck. The receiver for the mule drive is used to retain the front axle of later model Wheel Horses. Lincoln at A-Z should be able to fix you up, give him a call. https://www.a-ztractor.com/ Edited November 19, 2024 by 953 nut add photo Share this post Link to post Share on other sites
siebenaler 114 #3 Posted November 20, 2024 Okay. ? Do I need to install something On the tractor to accept the mule drive. Share this post Link to post Share on other sites
gt14rider 969 #4 Posted November 20, 2024 (edited) You will need to modify the front attach o matic, off set about a inch. The gt14 is wider than other tractors. If you need measurements let me know. Edited November 20, 2024 by gt14rider 1 Share this post Link to post Share on other sites
peter lena 9,554 #5 Posted November 20, 2024 @Mark siebenaler just a suggestion , while you are right there , cleaned out and repacked those bearings with , lucas green HD chassis grease , why ????? 550 deg flash point , also polyurea ( anti sling ) rating , talk about smooth quiet , never did your set up , but if they are 6203 ( 3/4 ) ID bearings , the wide rubber side grease shields , carefully remove , small flat putty knife or flat pocket screwdriver . clean out , flush with carb cleaner , wipe dry , repack , reinstall seals , lay it out as you disassemble , vital to function correctly , might even do a similar detail function , on the PTO LEVER FUNCTION , start point next to battery, like this often refer to this area as a gold mine for improvements , my 3 PTO LEVER DRIVES , WORK AMAZINGLY SMOOTH / EASY , ALSO EASY TO DO , PETE Share this post Link to post Share on other sites
953 nut 62,979 #6 Posted November 21, 2024 23 hours ago, Mark siebenaler said: Do I need to install something On the tractor to accept the mule drive. Yes, the receiver for the mule drive can be salvaged from any late model parts tractor. A-Z can fix you up. 1 Share this post Link to post Share on other sites
