QcDestor 0 #1 Posted November 19, 2024 Hi y'all! I'm quite new to this forum (and to wheelhorse tractors as a matter of fact). I've been looking for a chart that has been mentioned several times that shows weather or not a certain tiller will fit on a certain year tractor. I've been searching on and off for a couple of days and haven't managed to land it. There's a tiller not so far from my place for sale and i'm wondering if it would fit on my 516-8 tractor. This seems like a genuinely solid and informative forum and I love the idea of now being apart of it! Cheers ! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #2 Posted November 19, 2024 Welcome to Red Square. Model 71252 is a 2008-2010 XL 380H lawn tractor and see no tiller available for that model. One has shown up in South America so may be an export model which often have few ground engaging attachments listed. Here is a list of tillers that will fit the 516-H (Hydro transmission). There was never a 516-8 model which has 6 forward speeds. The 07-36TL03 was sold the year of the 516-H tractor. The chart you are looking for will list 3 tiller models at best because that is all there is room for in the charts. 1973-1974 tiller model 7-1251 Uses tiller hitch 103629 Rear axle hitch mounts under rear axle 103632 idler arm pivots in hitch No rear shield [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1975 tiller model 7-1252 Uses tiller hitch 104757 Rear axle hitch mounts under rear axle 104660 idler arm bolted to hitch - following models welded 104437 rear shield mounted on 104438 rear piano hinge [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1976 tiller model 67-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 104437 rear shield mounted on 104438 rear piano hinge [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1977 tiller model 77-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 104437 rear shield mounted on 104438 rear piano hinge [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1977 tiller model 77-36TL02 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1978 tiller model 87-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps No belt guard on front idler assembly [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1979 tiller model 97-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1980-1982 tiller model 07-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps Belt guard on front idler assembly retained by pulley shaft nut [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1983-1985 tiller model 07-36TL02 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle First belt guard on front idler assembly to be retained by bolts to a welded-on bracket [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1986-1989 tiller model 07-36TL03 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1990-1991 tiller model 07-36TL04 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1992 tiller model 07-36TL05 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1993-2001 2003-2007 tiller model 79370 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1 Share this post Link to post Share on other sites
QcDestor 0 #3 Posted November 19, 2024 1 hour ago, gwest_ca said: Welcome to Red Square. Model 71252 is a 2008-2010 XL 380H lawn tractor and see no tiller available for that model. One has shown up in South America so may be an export model which often have few ground engaging attachments listed. Here is a list of tillers that will fit the 516-H (Hydro transmission). There was never a 516-8 model which has 6 forward speeds. The 07-36TL03 was sold the year of the 516-H tractor. The chart you are looking for will list 3 tiller models at best because that is all there is room for in the charts. 1973-1974 tiller model 7-1251 Uses tiller hitch 103629 Rear axle hitch mounts under rear axle 103632 idler arm pivots in hitch No rear shield [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1975 tiller model 7-1252 Uses tiller hitch 104757 Rear axle hitch mounts under rear axle 104660 idler arm bolted to hitch - following models welded 104437 rear shield mounted on 104438 rear piano hinge [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1976 tiller model 67-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 104437 rear shield mounted on 104438 rear piano hinge [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1977 tiller model 77-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 104437 rear shield mounted on 104438 rear piano hinge [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1977 tiller model 77-36TL02 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1978 tiller model 87-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps No belt guard on front idler assembly [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1979 tiller model 97-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1980-1982 tiller model 07-36TL01 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle 106092 rear shield mounted by three straps Belt guard on front idler assembly retained by pulley shaft nut [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1983-1985 tiller model 07-36TL02 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle First belt guard on front idler assembly to be retained by bolts to a welded-on bracket [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1986-1989 tiller model 07-36TL03 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1990-1991 tiller model 07-36TL04 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1992 tiller model 07-36TL05 Uses tiller hitch 105543 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1993-2001 2003-2007 tiller model 79370 Rear axle hitch mounts under rear axle [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] Wow I could not have asked for a better answer! As far as my tractor: I guess I must be dizzy from reading so much wheel horse, my tractor is indeed a 516-H. Rest assured I am not confused weather my tractor has an 8 speed or a hydrostatic tranny. Lol. I guess I didn't get the model numeration exactly correct, it is in fact a 7-1252. Thanks again and best regards. Share this post Link to post Share on other sites
953 nut 57,839 #4 Posted November 19, 2024 Here is the chart you were looking fort, save it to your computer for future reference. 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,749 #5 Posted November 19, 2024 Pictures of the tractor? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #6 Posted November 19, 2024 Sorry did not realize that was an attachment model number - makes sense now Later on Toro dropped the dash from many of the attachment model number but not all. When searching try 8-xxxx and 8xxxx. Dash is often necessary. Share this post Link to post Share on other sites
QcDestor 0 #7 Posted November 19, 2024 2 hours ago, TonyToro Jr. said: Pictures of the tractor? I'm overall not a big picture guy but I might drop one on my profile sometime! Share this post Link to post Share on other sites
QcDestor 0 #8 Posted November 19, 2024 46 minutes ago, gwest_ca said: Sorry did not realize that was an attachment model number - makes sense now Later on Toro dropped the dash from many of the attachment model number but not all. When searching try 8-xxxx and 8xxxx. Dash is often necessary. Alright, duly noted. Share this post Link to post Share on other sites
