MainelyWheelhorse
What do you guys do about vibration when the tractor is running?
MainelyWheelhorse
Hey guys, what do you do about the vibration from the engine. Was there something in place from the factory that combatted it? Both my 308 and 312 have significant vibration when the engine is running. It’s almost like something is slightly unbalanced. I have looked at anti vibration pads, and checked the mounts to see if it was supposed to have some sort of dampening. Thanks!
kpinnc
I would check both machines drive belts for a stiff spot. Oftentimes a machine that sits for a while will get hard spots in the belt. It will definitely add to your vibrations.
Your 308 has no balance cancelling in it. Even though your 312 has balance gears internally, many of us remove them as they tend to destroy the engine if they fail.
I would say if you have a bit of vibration at idle, that’s fairly normal of these old Kohler engines. It should clear up as RPM is increased.
As the old saying goes: “Wheel Horse makes it, Kohler shakes it”… :rolleyes:
  • Like 5
adsm08
Agreed, some vibration is normal.
I grew up mowing with a 310 and I still remember how weird my hands felt after 2 hours of driving it. My hands felt 'buzzy' for lack of a better term, and everything I touched felt like rabbit's fur.
  • Haha 4
MainelyWheelhorse
@kpinnc and @adsm08 thanks for the input. The 312 has been pretty babied most of its life, but the 308 was pretty beat up when I got it. I figured I’d check if I was missing parts or something rotted out. Thanks!
@adsm08 I remember that as well my parents had a Simplicity that was like that. And I couldn’t hear well for a bit after too.
adsm08
Hearing was never an issue unless I was still on the tractor. My dad has always been obsessive about ear protection.
Going to the gun range and shooting even a .22 now he has ear plugs, and a pair of muffs with active noise cancelling.
MainelyWheelhorse
@kpinnc I wouldn’t be surprised if the balance gears are still in the 312 as all the original owner did was mow his lawn with it.He saved  the bill of sale and all the manuals he got the day it was new.
ebinmaine
@MainelyWheelhorse
It's possible wearing a particular kind of gloves may help quite a bit. You might have to experiment a little to get the right pair.
squonk
Mechanics Wear Impact gloves with the gel palm.
rmaynard
My wife can't use a hand-held gas leaf blower. It causes her whole arm to go numb. However, that's  not the case with me and I have never had any problems with Kohler single cylinder engines vibrating to excess. I know in 1978 Wheel Horse started using the anti-vibration "shaker cradle". I guess someone thought there was too much vibration going on. I believe that every person has their own level of tolerance for vibration. Maybe mine is high. To me, it's all part of the experience we affectionately call seat time.
Edited by rmaynard
  • Like 4
tunahead72
17 hours ago, MainelyWheelhorse said:
...  I have looked at anti vibration pads, and checked the mounts to see if it was supposed to have some sort of dampening...
I would check all the engine mounting bolts, make sure they're tight.  I know I've seen torque specs for those bolts somewhere, but the one time I tried I couldn't get my torque wrench fitted on the bolts well enough to be useful, so now I just check them every once in a while and make sure they're good-n-tight.
SylvanLakeWH
2 hours ago, 953 nut said:
I kinda enjoy the vibration.          :hide:        I'm nearly 80 and some days that is the most stimulating feelin I get.            :ychain:
:text-yeahthat:
Some people spend thousands on massage chairs... :scared-eek:
We get it for (almost) free!!! :D
  • Haha 1
Bill D
If the vibration really bothers you, consider purchasing a tractor with a twin cylinder engine.  Definitely a noticable difference in vibration.  The Kohler KT/M series are probably the smoothest followed by the Briggs and Onan, at least in my opinion.  I've had all of them and definitely notice a difference in my hands after an hour of mowing.
pfrederi
:text-yeahthat:
For long mowing hours C-175 or 418 are my got to tractors  so much smoother...
  • Like 6
MainelyWheelhorse
@kpinnc @adsm08 @ebinmaine @squonk @953 nut @rmaynard @tunahead72 @SylvanLakeWH @Bill D @pfrederi
Thanks all for the input everyone! was just curious if the amount vibration was normal. Both have sat outside before I got them long enough so rubber stuff like the shift boot was pretty nonexistent on both the 312 and 308 but more so on the 308. I figured if anything else was rubber like a dampener, it might be long gone too.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • adsm08
      By adsm08
      So while mowing tonight the 855 suddenly got a nasty vibration. When I bought it it seemed pretty smooth, especially for an old tractor, a month or so ago it started with a little vibration, nothing worrisome, and really only felt in the foot rests. Tonight while I was mowing it got worse all of a sudden. I still only feel it in the foot rests, but now it is like standing on one of those shiatsu massage machines. At first, when it started I stopped and checked the oil, which was a bit low, so I topped it up, and the vibration went away for a while, but came back.
      Any ideas where I should start looking? I'm going to bring my timing light home tomorrow and check that.
    • Hodge71
      By Hodge71
      Not the Beach Boys by any means but I can say that this thing vibrates worse than an old panhead Harley with a fouled plug. Now I have never owned a 14 Kohler but I have a 12 and a 16 and this is much worse than both. I was told possibly rebuilt with no balance gears? Anyone.....Anyone?.... Also have pictures and questions on the year of this engine. It has an odd flywheel screen. Different than the 12 and 16 as well. It has a box hanging off the side of the engine that my 12 and 16 don't have. Also Im having electrical trouble. The headlights don't work, the electric clutch doesn't work and the battery only seems to be receiving 13.4 volts at full throttle. Is that enough to charge the battery or are there electrical issues I need to figure out? I know my 12 and 16 both have 13.9 or 14.1VDC respectively. The 416 Onan I built for my Dad had 17VDC but it was a bad voltage regulator and its now happy at 14.5 VDC...So whats the scoop on this thing? Any engine gurus have an idea?
    • Rentalman
      By Rentalman
      I've been a Wheel Horse Dealer since 1979. I still have (12) 48"Snow/Dozer Blades still available Model # 79364. I am selling these for $250 ea. Well under dealer cost and a steal from the MSRP of $699, I got stuck with a shipment of 26 8 years ago.They fit all CSeries-300Series-400Series and some 500Series but adaptor kit needed
      You can reach me at Gaithersburg Rental
                                        219 E Diamond Ave
                                        Gaithersburg, Md 20877
                                        301-926-0044
                                       mon-sat 730-530
