Alrashid2
Can anyone help me tell if my tires are Tubeless or Tubed?
Alrashid2
Hey guys. All 4 of my newly acquired Wheel Horse 312-8's tires are dry rotted and cracked, but have near perfect tread. The fronts are definitely tubeless, and losing air, so going to get tubes put into them. The rears, however, I'm not so sure of. They aren't losing air, but I'd like to put tubes in them at the same time just for peace of mind. However, if they already have tubes in them, no point right?
Can anyone help me figure out if they are Tubed or Tubeless? Attached some photos. They're Carlisle 22x7.50-12 tires, don't say "Tubeless" anywhere on them. However, the valve stem shape made me think they were tubeless but I'm not quite sure...
Tried deflating one and poking in but I just can't get a good look and didn't want to risk ripping the tire.
Thanks for the advice all! I'm real thankful for this place
Edited by Alrashid2
Photos
ebinmaine
That last photo would lead me to believe that you have a tubeless tire there. You can't see the hole that the stem should be going through.
  • Like 6
Alrashid2
Thanks for replying. Ya, that is what I was thinking too... The fact that the valve stem is pretty wide. But I wasn't sure and googling is not helping me find anything at all.
Seems wild they're still holding air if tubeless!
pfrederi
Fat rubber around the hole tubless
Alrashid2
Thanks for confirming. Guess I better take all 4 wheels to my local guy to get tubes put in... thanks guys!
ri702bill
A caution on tubes that come from an "offshore" supplier. Be prepared to be disappointed. Regardless of its origin, I inflate the tube by itself at least 3 days before I plan to use it. Do not destroy the packaging - good chance you will need to return it.....
The larger rear tires are not so bad to fish a tube into... the smaller 6" fronts are a true PITA.
Alrashid2
Thanks for the advice. My local shop seems to use quality parts and their price on their tubes reflected that - double what I saw on amazon and ebay, so thinking they should be good. We'll see. Thanks again
rjg854
If they're not leaking air, l feel it would be better to leave them alone.  Putting stress on the sidewalls taking them on and off may cause more harm to the tires. Leave well enough alone.  That's my 2 cents.
  • Like 5
ebinmaine
Seconded.
ri702bill
But - if they do not hold air - nothing ventured, nothing gained...
Retired Wrencher
@Alrashid2 Stick with us for any thing you need to know about Wheel Horse related. And :WRS:
  • Heart 1
Retired Wrencher
10 hours ago, ebinmaine said:
Seconded.
:text-yeahthat:  I third that.
Gravely Horse
For what it’s worth, I’ve used green slime in several yard equipment tires that have good tread, but dry rotting or puncture damage that would cause it to lose air. If you roll it around a lot to get full inside coverage, it works quite well.
Mine have held air all season. In fact , the front tires on the 50” gravely deck attachment take like 50 psi, but are tiny. When I bought it, one wouldn’t hold air more than a day, and after the slime, it held all summer.
Just a thought.
SylvanLakeWH
:text-yeahthat:
Used some of that from dad's garage when we cleaned it out a few years back... on my garden utility trailer... cracked and wouldn't hold air... it was free so why not?
Has held up with zero air loss...
Hope i didn't just jinx myself...
Alrashid2
Thanks guys, wish I had seen your responses before dropping off the tires yesterday! My guy seemed confident he could put tubes in them, and said I could pick up tomorrow. So we'll see! If they rip, then I'll just get new tires. I don't like waiting for things to break and rather be proactive, as my luck always seems to have things fail when I need them most!
Alrashid2
Got my wheels back! He aired them up to 19 PSI but I dropped to 12 PSI as per the service manual.
Here are the tubes he used.
Tires are 15x6-6 and 22x7.5-12
ebinmaine
1 minute ago, Alrashid2 said:
the tubes he used
Not Chinese. Decent brand.  :handgestures-thumbupright:
  • Heart 1
Alrashid2
Good to know!
Only thing that concerned me is he used a 23" tube in a 22" tire. But I know the exact size is hard to find
ebinmaine
14 minutes ago, Alrashid2 said:
Good to know!
Should be fine.
Tubes are usually able to be used one size up or down. Maybe more.
Alrashid2
Thank you @ebinmaine. More peace of mind from you boys. Appreciate you all!
