Goldnboy 910 #1 Posted Saturday at 05:28 PM (edited) Haven't seen much on creating or building the wheelbarrow tub cart that hooks onto a sleeve hitch. So i started out with a brinly sleeve hitch Disc at auction no one wanted so I gave $10 and removed the hitch frame and sold the remaining disc on Marketplace. The remaining items with the exception of the flat metal plate and wheelbarrow (obviously) where made from scraps laying around. I decided to fill the bolt holes in the tub with JB weld. Edited Saturday at 06:35 PM by Goldnboy Share this post Link to post Share on other sites
SylvanLakeWH 25,486 #3 Posted Saturday at 08:06 PM Looking forward to seeing your work! Here's what i came up with... 2 that might give you some design ideas... 3 1 Share this post Link to post Share on other sites
ebinmaine 67,231 #4 Posted Sunday at 01:00 AM 4 hours ago, SylvanLakeWH said: Looking forward to seeing your work Share this post Link to post Share on other sites
Goldnboy 910 #5 Posted Sunday at 03:30 PM (edited) So to have wheelbarrow close to level you need to raise the flat end of the wheelbarrow by about 2"(the round end is the dump side). I did this by placing a piece of 2" receiver tube on the frame. Now the frame does have a drop/bend but not enough to aid with the need to raise one end by making the ears shorter by 2 inches and leave enough metal to allow a large pivot bolt/pin to be used (i used 5/8"') Edited Sunday at 03:32 PM by Goldnboy 2 Share this post Link to post Share on other sites
Goldnboy 910 #6 Posted Monday at 12:49 AM The slots on the hinge plate are probably not necessary since your not going to need that once set in place they just happened to be in the metal I used. Share this post Link to post Share on other sites
Goldnboy 910 #7 Posted Tuesday at 12:56 AM (edited) Here the latch is similar to the original except the threaded bolt with spring is welded to the top bracket and sets on top of a bolt head. The original design is a plow bolt ..and that is to hard for me to replicate. The u shape in the handle was mostly grinding to fit the lip of the wheelbarrow. Edited Tuesday at 12:58 AM by Goldnboy 2 Share this post Link to post Share on other sites
Goldnboy 910 #8 Posted Tuesday at 05:21 PM Here is the final assembly before I tear down and prime and paint. Note this is a 5cu ft vs a 4 cu ft that brinly originally used so I should be able to get about 400-500lbs of material in here. 1 1 2 Share this post Link to post Share on other sites
