clueless 2,974 #1 Posted 11 hours ago I need the correct part numbers for the front spindles for the 6" wheels or they the 110212 and 213? Share this post Link to post Share on other sites
Lee1977 6,631 #2 Posted 8 hours ago (edited) Since Toro dropped the Wheel horse Parts Viewer there is no clear answer. There are two diferent 6" spindles. My 85 model 312 set has the cotter key holding the spindle to the axle. My later model 312 has a snap ring, not sure what year it is. Both spindles will work as the axle number did not change 5638 and 5638-01 on some later models. I've checked numbers on Parts Tree all had a "?" beside them, Toro kept changing number each year, so on way to tell. Edited 8 hours ago by Lee1977 Share this post Link to post Share on other sites
peter lena 8,562 #3 Posted 5 hours ago @clueless don,t forget about the , washer bushings , to the wheels 3/4x 1-1/4 , 18 ga , also a good time to clean out and re grease , what ever bearings you have , the original lube is trash , lucas green HD walmart 8 $ , combination of wheel side shucking, elimination and polyurea hi stress grease , makes that entire set up work with ease . having that in every area , that used to whine , and lubrication fail , is a worthwhile change . amazing transformation to entire , PTO belt driven set up , once you do it , you will convert other bearing failure areas , ever listen / feel the bearing drag , on a belt driven anything ? my decks spin by hand at pto down belt drive area . just a suggestion . pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,018 #4 Posted 5 hours ago 1990 312-8 with 6" front wheels Left front spindle 113379 Right front spindle 113380 Share this post Link to post Share on other sites
