tmix61
Front pump D200
tmix61
I have a 1977 d200. I took the bolt out and there is no ball in spring behind there. Is there supposed to be if so does anybody have these parts
pfrederi
Are sure the ball isn't stuck in the housing?
It is just a plain ball.  The reverse check valve (directly below) uses the same one you could measure it and get a ball from McMaster or where ever.
WH part number is 103216
tmix61
No spring and no ball.
pfrederi
I checked Wheel horse parts and more catalog they do not show the spring but might be worth calling him.  also LJ Fluid Power  Delton MI has extensive experience with Sunstrands
gt14rider
Looked this up couple years ago, got some crossover #s . SEPW. (small engine parts warehouse )  item # 48, ball 25-2490 and #49 spring 25-2480. Got got some more crossover  #s let me know. LJ at (LJ fluid power) helped with a lot of parts.
  • Excellent 2
