little red riding horse 223 #1 Posted October 31 Hi people , Couple of questions regarding the c175 , what should the cyl compression be ? (mine is reading 75psi) havent checked valve clearance yet or done leak down test.. secondly are the studs and nuts available for inlet manifold that the carb uses to bolt onto ? many thanks as always Phil Share this post Link to post Share on other sites
953 nut 55,393 #2 Posted October 31 This manual should be helpful. When the compression test was done had the engine been warmed up and the choke and throttle held wide open? Share this post Link to post Share on other sites
