Countdown To Christmas!
BuffaloD200
D series Belt Replacement
BuffaloD200
Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
Same question for my 80 D200 as well really.
Using the recommended 4L490W belt.
Thanks
Edited by BuffaloD200
misspell
pfrederi
Not good pictures but there is a description....
BuffaloD200
That's it?  Flip the eccentric bolt over?
I wasn't expecting rocket surgery, but I thought it would be slightly more complicated.  I'll poke around with it later.
Thanks for the help
BuffaloD200
This part, with the adjustable slot?
BuffaloD200
I've copied the text here, for future reference.  Those manuals can be tough to read.
1973-1974
Installation of Drive Belt
Remove grille from tractor.
With pivot arm eccentric (R) in position shown by dotted lines, place V-belt on tractor engine pulley (forward groove) and gear box pulley.
To put proper operating tension on V-belt flip pivot arm eccentric (R) over center as illustrated.
Adjusting Drive Belt Tension
If additional tension is needed on drive belt, remove clevis pin (Q) from yoke of turnbuckle (S) and rotate yoke assembly counterclockwise.
To decrease tension, rotate yoke assembly counterclockwise.
Replace clevis pin and hair cotter pin and snap pivot arm eccentric (T) over center to lock in operating position.
NOTE: Proper tension on V-belt will allow approximately 1/4" deflection when firm finger pressure is applied midway between pulleys.
BuffaloD200
Still no clue what the hell I'm supposed to be doing here.
Somebody have a real picture or video?  Hell, I'll take a line drawing.  Anything is better than that manual.
pfrederi
Sorry I do not have a blower for my D
The manual is hard to follow....
BuffaloD200
It sure is.  The picture is so washed out.
I'm pretty mechanically inclined, but I haven't seen anything that moves the pulley.  I've got to set aside some time and really get in there.
BuffaloD200
After reviewing the manual for an IH H42/48 blower, which had significantly better pictures, and just poking around - I got the belt on.
But the belt tensioner still has me confused.
It appears it was originally mounted upside down.  So I flipped it according to the IH manual but now I don't know if mine is bent or not.  I know the threaded clevis bolt is (clearly bent) but the top part of the bracket has a curve, and I don't know if that is on purpose.
And what I think is part T snap pivot arm eccentric doesn't line up with anything
BuffaloD200
Ok so I've determined that my bracket is definitely bent.  I stuck it in a vise and managed to get it mostly straight.  The belt tension is way too high, the auger engages when the PTO is not.
That threaded bolt with clevis, is that available anywhere or should I just weld something together?
BuffaloD200
Having a real hard time removing the PTO.
My friction disc is mostly gone.
Yes.  I've looked at the manual.
I have a key way but no key...
From what I can tell, all that's holding me back right now is this stubborn snap ring.  I've got it soaking in knocker loose.  We'll see what happens.
What a PITA just to change a belt.IMG_20241215_171434418_HDR.jpg.a4268efafecaf048b9baf3e0f938808c.jpg
  • Similar Content
    • pieblaster
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
