Tee man 0 #1 Posted October 23, 2024 So my 417a when I move the lever to go forward I push forward and the Tractor doesn't move same thing for reverse this is my first wheel horse can someone help ??? Share this post Link to post Share on other sites
Ed Kennell 40,387 #2 Posted October 23, 2024 to the Tee man. Is this a new problem, or did you just get the tractor? Does your 417A have a transmission engagement lever? Could be several issues. broken drive belt broken belt tension spring missing key in transmission input pulley loose hub on an axle. disconnected linkage on motion control Look inside the right rear wheel to see if the transmission pulley is turning and report back. 3 Share this post Link to post Share on other sites
ebinmaine 70,527 #3 Posted October 23, 2024 Can you post pics of where the levers are on your tractor? Share this post Link to post Share on other sites
953 nut 57,740 #4 Posted October 23, 2024 Does the hydraulic lift operate? Here is a Manual that may be helpful. Share this post Link to post Share on other sites
