O2B__ 7 #1 Posted October 20, 2024 While mowing along fine, engine suddenly died and no spark. I thought to replace points and condenser, but I don't even see a points cover. I have a conventional looking coil and capacitor. Can anyone point me in the right direction? Thanks. Share this post Link to post Share on other sites
953 nut 57,833 #2 Posted October 20, 2024 Yes, your engine came equipped with ignition points. Sudden failure probably isn't the points. Before you go out and buy parts you may not need I would suggest you do a bit of trouble shooting first. With the PTO off, transmission in neutral, and parking brake applied, Turn the ignition switch to the run position and check the voltage at the ignition coil terminal that has a wire coming back to the ignition switch. You should read 12 +/- volts there. Now move the meter to the terminal that has the condenser on it and see what voltage reading you see while holding the key in start, should be a pulsating 12 volts. The ignition points are under a cover at the other end of the wire from the condenser side of the ignition coil. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #3 Posted October 20, 2024 Share this post Link to post Share on other sites
O2B__ 7 #4 Posted October 22, 2024 Thanks to each of you for the information. I'll do the trouble shooting today. Share this post Link to post Share on other sites
SylvanLakeWH 27,494 #5 Posted October 22, 2024 Same exact thing happened to me. Check for blown fuses. That's what happened to mine... Same time check all grounds. clean and tighten. Share this post Link to post Share on other sites
O2B__ 7 #6 Posted October 22, 2024 OK, so I had a little over 12 volts at the coil + terminal, and pulsating voltage at the - terminal when cranking. Tried again - no spark. Took out the spark plug lead from the coil and saw that there was some oil on the connector and the connector had some blackening. Wiped off the oil, wire brushed the connector and now a strong spark. So I'm wondering if the oil on the spark plug lead and in the coil socket is coming from a failing coil? 1 Share this post Link to post Share on other sites
953 nut 57,833 #7 Posted October 22, 2024 2 hours ago, O2B__ said: I'm wondering if the oil on the spark plug lead and in the coil socket is coming from a failing coil? Glad you got it going. Something to keep an eye on, the coil has oil in it. 1 Share this post Link to post Share on other sites
