WH654
Best 6 speed for a 1962?
953 nut
4 hours ago, stevasaurus said:
.I am going out on a limb here.
4 hours ago, ebinmaine said:
I'll set on the same limb
Careful there,      :scared-eek:            two big boys like you two on one branch could be dangerous.         image.jpeg.d74181724f42d25dfb4c5f1a67fb39bf.jpeg         :ychain:
  • Haha 3
ebinmaine
Big limb Richard.
BBIIIIIGGG.
  • Haha 2
Pullstart
@WH654 bottom line, if you want a transmission with low range, it’s hard to say you could go wrong.  Most of us with round hoods and low range, did it before looking around on the internet.  That’s the beauty of Wheel Horse.  Simple.  Tough as nails.  Always improving.  On the older designs.
  • Excellent 2
stevasaurus
OK...the 3 Limited Slip manual transmissions (#5060, #5071 & #5073)  all have 10 pinion differentials and that means they also have 1 1/8" axles...all of them !!
All Wheel Horse transmissions (and there are 3 & 4 & 8 speed ones) that have 4 pinion differentials are 1" axles.  In other words, if you have 1" axles, you have a 4 pinion differential...all of them !!
All Wheel Horse manual transmissions that have 1 1/8" axles have either 8 or 10 pinions...and are 6 or 8 speed...all of them !!
The exception is the Wheel Horse "Heavy Duty" transmission.  This one has 1 1/8" axles with the bevel gear differential...it is on a few horses like the #953 and is a 3 speed.
:USA:
  • Excellent 2
953 nut
:USA:
Lily Tomlin GIFs | Tenor
WH654
Well, the guy that was selling the raider 10 from Facebook sent me more photos of the tractor and it looks rough. The trans tunnel is full of leaves like it’s been sitting outside uncovered and both axle seals are leaking.
i’m in no hurry because I wouldn’t work on this until spring so, I’ll look for a better tractor/transmission.
stevasaurus
Well, if you are going to wait that long, you might as well wait until next June and find a good one at the "BIG" show.  Wheel Horse Collector's Club Show in Penn.  :occasion-xmas:
BTW, the detent spring measures 3/16" OD x 1 3/16" Long.  It is a little heavier gage the a ball point pen spring.
  • Excellent 2
WH654
Where at in Pennsylvania is the big Wheel Horse show? That would be great
953 nut
South Mountain Fairgrounds between Chambersburg and Gettysburg in southern PA, weekend following Father's Day
  • Heart 1
