peter lena
front wheel bearing shimming help
peter lena
https://www.amazon.com/Hillman-Group-2808-Machine-Bushing/dp/B00HYN42IC   often refer to front wheel  SHUCKING - SIDE PLAY , on a recent replacement , these 3/4 x 1-1/4 x 18 ga , really  helped in the rolling  fit ease , it also  transfers the  play factor to  related steering linkage dry joints , like a red aerosol  spray tube , for original joint type , help . any direct side to side , wheel play  quickly eats up those bearings . as you refit , DETAIL / IMPROVE ORIGINAL INTENT , also went over every related contact  point , typically get  many years  on my  stuff , just regularly  check it over for any related issues . my neighbors  stuff is solid rot / rust , don't even bother  referring to anything he has ,  stay greasy , pete
peter lena
@953 nut also installed new XIKE bearings model # 532009040 much better quality than  bearings in there . much smoother  overall steering , easy / simple , stop it before it happens , keep rollin , pete
peter lena
@ri702bill  the related steering linkage , really responded to the , red spray grease , in all horizontal  movement areas , snugged up wheel settings , while  up on jacks , hit every connection point , the drag reduction was  much better .  simple easy , pete
ri702bill
Probably better than the day it left South Bend
Treepep
Bought a party pack of those mochine washers a while back.  I was making good decisions that day!
peter lena
@Treepep  regularly refer to detailing in linkage / lever function , making it work with a solid , smooth ease , once I  saw / felt  the complete change , started doing that to every , connection point / also lubricated , washered up , changed to a HEIM JOINT  , the operational function is like effortless , what a concept ! and it also easy to do ! personally start at the PTO LEVER POINT , talk about  a train wreck !  that behind  /  battery side area , can easily be improved , easily done , HUGE IMPROVEMENT , pete
