Redtickuleez
Brand new old stock
Redtickuleez
what Wheel Horse does this trans fit.?.. have chance to buy it
pfrederi
Used in 1974-1977 C-160
953 nut
:WRS:
The Sundstrand 91-1140 is listed as being installed on the 1974 to 1977 C-160 model. The drive pulley being splined rather than being keyed to a round shaft would be tie primary difference.
Buying a used Sundstrand without being able to test it is a real crap-shoot unless you know the seller and they stand by their product. A-Z Tractor can be trusted and tests everything they sell.    https://www.a-ztractor.com/
Ed Kennell
I have swapped several models of Sundstrands in different tractors.      I believe the mounting and motion control linkage is the same on the 90-2046, 90-2062, 90-1136, 90-1137, and 90-1140, so they should be interchangable.     Maybe Paul  @pfrederi can confirm or correct me ?
pfrederi
74-77 is too new for me.  D series all had splined shafts.  My Charger/Electros all had woodruff keys.  Maybe WH thought 16hp was too much for a woodruff key???  Swapping the drive pulley would resolve any mismatch.
Redtickuleez
was any of these replys to my question? if so i still have the same question... im slow fellers
  • Confused 2
Ed Kennell
Paul answered your question.
I have installed a 90-2046 Sundstrand from a 1972 Charger 12  in a 1974 C-160 that had a weak 90-1140 Sundstrand.
It was a direct bolt in requiring no changes to the linkage or input pulley.        As I stated above, I believe all the 90 series Sundstrands are interchangable.  The tow valves are different and the input pully/shaft connections are different, but that does not effect the installation.
What tractor are you planning to use this transmission ?
953 nut
On 10/10/2024 at 9:20 AM, 953 nut said:
:WRS:
The Sundstrand 91-1140 is listed as being installed on the 1974 to 1977 C-160 model. The drive pulley being splined rather than being keyed to a round shaft would be the primary difference.
How much more direct an answer do you want?
  • Like 5
clueless
Bless your heart.
  • Haha 2
953 nut
You asked what Wheel Horse it fits, we told you, what is your other question we were supposed to guess?
  • Haha 3
EB-80/8inPA
You fellers are in rare form here.
Edited by EB-80/8inPA
  • Haha 2
wallfish
Nope, It's obviously going to remain a complete mystery
  • Haha 2
Ed Kennell
      Free Don't Understand Cliparts, Download Free Don't Understand Cliparts ...
  • Haha 2
Redtickuleez
daaaaayum thanks
Redtickuleez
So will it mount on a D-180???? i know ya prolly answered that. But my ADHD wouldnt let me read it all
Ed Kennell
Sorry Red, my lazy nature refused to let me type it again.
pfrederi
Not with out a lot of work...Motion control is on the wrong side...could be fixed but,,,What is your level of being into mechanical adjustments.
Redtickuleez
nada... can i ask something else, please? and not that
gt14rider
You don't need permission. Spit it out already or do you want us to guess. :angry-banghead:
Gasaholic
Not to mention, I thought the D-180 had the hydro pump mounted up front in front of the operator position, and then hydro lines ran from there to the transmission..... or am I thinking of a different D-series?  This one has the hydro and trans in one pieces, so definitely wouldn't work in a D-180... Although as mentioned with some mechanical skills and know-how of the sundstrand hydros, one could rebuild the existing D-180 from parts of these sundstrands....
953 nut
Please do, we all learn from questions asked and answered.
pfrederi
You can separate the pump from the motor then mount the pump on the front end of the D series manifold,  However motion control will be on wrong side and have to be switched inside the pump. and I forgot to ad the input shaft for a D has to be splined not keyed so you would have to swap out input shaft.  It would not be a project I would want to tackle anymore.
Redtickuleez
Using loader recently and all of a sudden when I turn steering to the left it seems like it is catching on something and wheels don't turn left
H E L P     me  Please
Edited by Redtickuleez
Redtickuleez
I think I need to sell this thing coz my mechanicing skills are wurss than my speeling...lol
Ed Kennell
H E L P     me  Please
Dead u wrun ovr a stic an jam up yer sterin ?     Ya cud jest turn write an back up.  Sameas turnin left.
Edited by Ed Kennell
  • Haha 1
  • Confused 2
