JCD 60 #1 Posted October 9, 2024 My clutch disc assembly is showing up today from K and B so I go to start taking things apart and noticed I don't have the small friction plate that rides on the edge of the disc, the bracket is there as well as the bolts and washers and nuts but no piece that rides on the rim. Is it dangerous to run it without that piece, I read that it is a safety feature or is it ok just to let the pto wind down. Thanks, Jim Share this post Link to post Share on other sites
squonk 41,871 #2 Posted October 9, 2024 PTO bell will just spin if there is no belt on it. Causes a little more wear on the bearings but that's it 3 Share this post Link to post Share on other sites
ri702bill 8,686 #3 Posted October 9, 2024 You are talking about the adjustable brake bracket / pad assembly, right?? A lot of folks just leave it off.... Share this post Link to post Share on other sites
JCD 60 #4 Posted October 9, 2024 29 minutes ago, ri702bill said: You are talking about the adjustable brake bracket / pad assembly, right?? A lot of folks just leave it off.... yes that's the one. Just wanted to make sure it was ok. Thanks guys. 1 Share this post Link to post Share on other sites
Handy Don 13,040 #5 Posted October 9, 2024 3 hours ago, squonk said: PTO bell will just spin if there is no belt on it. Causes a little more wear on the bearings but that's it It’s one bearing or the other! 😁 Letting is spin means it’s turning the “throw out” bearing the same as if the PTO was engaged (although with less load on the bearing, for sure) If “braked”, it’s turning on the internal needle bearings. 1 1 Share this post Link to post Share on other sites
Ed Kennell 39,709 #6 Posted October 9, 2024 I always remove my PTO brakes. Makes it much quicker to change belts . And like Don noted, less hours on the big needle bearing. 3 Share this post Link to post Share on other sites
peter lena 8,961 #7 Posted October 9, 2024 @JCD removed , my brake pad years ago , after going over to hi temp / stress grease in every bearing , the entire unit spins with ease . pete 1 Share this post Link to post Share on other sites
cleat 6,828 #8 Posted October 11, 2024 Mine are all removed as well. I don't care if the pulley spins with nothing attached and if there is a deck, snowblower etc attached it stops anyways. Nice thing is that if you get the PTO bell all painted up nice then the brake does not scrape a bunch of paint off. 2 Share this post Link to post Share on other sites
