MainelyWheelhorse 765 #1 Posted October 6, 2024 I have what I’m thinking is a 42” rear discharge mowing deck I got with my 87 308-8. I’ve been all over the implement manuals page, and can find 42” RD deck but I’m not sure of the year. I’d assume it was an 87 like the 308 but I’m not positive. Thanks! Share this post Link to post Share on other sites
JCM 9,916 #2 Posted October 6, 2024 15-42RC01 Toro 42'' RD = 1989 1 Share this post Link to post Share on other sites
MainelyWheelhorse 765 #3 Posted October 6, 2024 1 hour ago, JCM said: 15-42RC01 Toro 42'' RD = 1989 Thanks, That definitely narrows it down. 1 Share this post Link to post Share on other sites
Gary S Minnesota 53 #4 Posted October 8, 2024 I have that same 42” RD deck. I also received “mulcher” insert ( molded plastic) with what appears to be two areas for the blades to revolve in. No makings or ID on the plastic. I can’t for the life of me get that mulcher in position under the deck. I’m wondering if the mulcher I received is actually for a different deck. Sorry no photo. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #5 Posted October 8, 2024 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #6 Posted October 8, 2024 If you can read the numbers in the bottom box of the decal that is the Julian build date that batch of decks were assigned for production. Share this post Link to post Share on other sites
Gary S Minnesota 53 #7 Posted October 8, 2024 Here is a photo of my “recycler”? Thanks for looking1 Share this post Link to post Share on other sites
Lee1977 6,917 #8 Posted October 8, 2024 If it fits a Wheel Horse deck it would be for a 37" two blade deck. Share this post Link to post Share on other sites
peter lena 8,970 #9 Posted October 8, 2024 @ GARRY S MINNESOTA , nice that the baffles are not there , have removed all of mine on my 3 decks , typically creates a rot box , that is never cleaned / aired out , been doing this for years , also store them over winter , with a minimal clean out and an oil soaking , found the combo of lubrication / heat , absolutely stops deck rot / rusting , also detail in a no fail bearing lubricant , in all related bearings. have zero grass debris in my decks , have them wall mounted over winter , just like picture , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #10 Posted October 8, 2024 The only kit I am aware off. Could be added to a 42" rear discharge deck that did not come with one. Share this post Link to post Share on other sites
Gary S Minnesota 53 #11 Posted October 8, 2024 Thank you for all the responses to my mulcher question. Pretty much confirms that the mulcher attachment I was given when I purchased the deck is not correct or even adaptable to the 42”RD. Share this post Link to post Share on other sites
Brockport Bill 1,777 #12 Posted October 10, 2024 here is photo of 42 recycler bottom if you were looking for photo ?? 1 Share this post Link to post Share on other sites
Gary S Minnesota 53 #13 Posted October 10, 2024 Thanks for the photo. that’s about what I envisioned it should look like. Noted the shiny triangular pieces near each of the blades. Are they too part of the kit—or something you designed? Share this post Link to post Share on other sites
Brockport Bill 1,777 #14 Posted October 11, 2024 9 hours ago, Gary S Minnesota said: Thanks for the photo. that’s about what I envisioned it should look like. Noted the shiny triangular pieces near each of the blades. Are they too part of the kit—or something you designed? when i got the one recycler mower deck it was not in good condtion and the "fins" as i call them were in bad condition rusted, cracked, fractured etc ---- so i took one fin to a welder fabricator - who on his computer engineer designed them to match and i had him make all new ones and I installed them with new bolts. I also had another recycler and cleaned rust and primed it then painted the bottom black Share this post Link to post Share on other sites
