Wvtroutbum81 174 #1 Posted 14 hours ago Engine experts, M12 with 2,201hrs. Oil has always been changed twice a year. Does not smoke or use oil, the head gasket was leaking on exhaust side. This is post cleaning Share this post Link to post Share on other sites
Wvtroutbum81 174 #2 Posted 13 hours ago 17 minutes ago, Wvtroutbum81 said: Engine experts, M12 with 2,201hrs. Oil has always been changed twice a year. Does not smoke or use oil, the head gasket was leaking on exhaust side. This is post cleaning Is there anything i should inspect while apart Share this post Link to post Share on other sites
adsm08 1,867 #3 Posted 13 hours ago The mating decks of the block and head should be inspected for any deformation. The correct way to do it is with a machinist's straight edge and some feeler gauges. I usually just pass the straight edge over the surface with a flash light behind it. If I can't see light under the bar I don't bother with the feelers. If the head needs any straightening you can deck it yourself by coloring in the entire surface and sanding it with a piece of sand paper wrapped around a piece of glass. There are others who are more familiar with that process than I am. 1 Share this post Link to post Share on other sites
kpinnc 11,615 #4 Posted 13 hours ago (edited) It looks clean, but of course impossible to tell if the bore is still within spec. As @adsm08 said, it’s a good time to check the head. @ebinmaine has some posts on here doing it the right way. If the engine still made good power and didn’t smoke, I say true the head and run it. Edited 13 hours ago by kpinnc Share this post Link to post Share on other sites
leabassett@sbcglobal.net 141 #5 Posted 12 hours ago New head gasket and head bolts. Than let her rip. Share this post Link to post Share on other sites
Wvtroutbum81 174 #6 Posted 12 hours ago 20 minutes ago, leabassett@sbcglobal.net said: New head gasket and head bolts. Than let her rip. Where is a good source for the bolts? do they have to be replaced Share this post Link to post Share on other sites
ebinmaine 66,710 #7 Posted 12 hours ago 39 minutes ago, kpinnc said: true the head and run it. 18 minutes ago, leabassett@sbcglobal.net said: New head gasket and head bolts. Than let her rip. Gotta true the head. It's almost certainly warped even if only a small amount. I do NOT install a cylinder head without trueing it. Ever. We use a piece of known flat steel. Tape a piece of sandpaper to the steel. There should be a thread on here describing the procedure. 3 minutes ago, Wvtroutbum81 said: Where is a good source for the bolts? do they have to be replaced If the engine has NEVER been apart the head bolts MIGHT be reusable. Older K series use normal Grade 8 bolts. Not sure about a Magnum. Share this post Link to post Share on other sites
Bill D 1,858 #8 Posted 12 hours ago The Magnum is basically a K series with electronic ignition. Grade 8 bolts should be fine. 1 Share this post Link to post Share on other sites
oliver2-44 9,478 #9 Posted 10 hours ago Now would be a good time to pull the carb so you can clean the breather and adjust the valve clearance. If the head checks out to be flat with a feeler gage go with it. But do check it’s 1 Share this post Link to post Share on other sites
953 nut 54,509 #10 Posted 52 minutes ago Once the head has been installed with the new head gasket and has run long enough to come up to operating temperature allow it to cool down and then re-torque the head bolts using the same sequence. Share this post Link to post Share on other sites
