WHX?? 50,698 #1 Posted September 30, 2024 I have had them weep before but never as bad as this one. Pretty good sized drop every minute. Anyone seen this before and have a cure? Share this post Link to post Share on other sites
oliver2-44 10,353 #2 Posted September 30, 2024 The k181 (gray replacement engine) on my C81 likes to slobber out the governor shaft when the oil level is at the full mark. it doesn't do it if its on the low end of the normal range. I've had the breather off and verified with the manual that it was installed correct and the little drain hole back into the block was open. I've also lapped the valves, valve guides seem a little loose, cleaned carb, etc. De-carboned head and measured bore and it was just within spec but, I really suspect the rings have more blow by than the breather can handle. It was missing the carb and had sat open for ? years before I got it. So for a $100 tractor I just run it at the low-side of normal and try to keep an eye on it. So, I'm interested if you figure anything out. 1 2 Share this post Link to post Share on other sites
WHX?? 50,698 #3 Posted September 30, 2024 1 minute ago, oliver2-44 said: oil level is at the full mark. it doesn't do it if its on the low end of the normal range. Interesting enough I had just changed the oil and is right at the full mark. It didn't do it before the change and only had less than a quart in and didn't do it. I use the patented @Racinbob method of draining old oil into a marked juicy juice bottle. Will recheck level and maybe remove a little ... see if that helps. it definitely is coming out the guv shaft. Will check the breather as well. 2 Share this post Link to post Share on other sites
squonk 42,508 #4 Posted September 30, 2024 I'm betting blow by is over- pressurizing the breather / gov area . There shouldn't be an excess amount of oil way up top unless overfull. A cylinder leakage test could confirm. I had a K341 that ran fine but leaked a tad out of the gov. Had half of the piston skirt missing. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #5 Posted September 30, 2024 Another possibility 1 1 Share this post Link to post Share on other sites
squonk 42,508 #6 Posted September 30, 2024 Worn guides will also over pressurize the breather area. 1 Share this post Link to post Share on other sites
wallfish 17,485 #7 Posted September 30, 2024 Yup, crank case pressure pushing it out 1 Share this post Link to post Share on other sites
WHX?? 50,698 #8 Posted October 1, 2024 3 hours ago, wallfish said: Yup, crank case pressure pushing it out Yep gotta be ... didn't get to it today. Old lady has been on me like a dirty diaper 'cause I spend too much time on tractors and not enough on the honeydo... 1 Share this post Link to post Share on other sites
ebinmaine 70,684 #9 Posted October 1, 2024 29 minutes ago, WHX?? said: honeydo So get HER to work on the honeydo.... 2 Share this post Link to post Share on other sites
wallfish 17,485 #10 Posted October 1, 2024 42 minutes ago, WHX?? said: Yep gotta be ... didn't get to it today. Old lady has been on me like a dirty diaper 'cause I spend too much time on tractors and not enough on the honeydo... Never ever never knock too much off that honey do list because it will NEVER get smaller anyway. Pace yourself and make excuses if necessary. LOL If you knock off too much of that list the next thing you know you have enough time to spend an evening binge watching Dowton Abby for hours! LOL Then you will need to get up early and clean up the leaves when there is still thousands left to fall off the trees. 5 Share this post Link to post Share on other sites
WHX?? 50,698 #11 Posted October 1, 2024 17 minutes ago, ebinmaine said: So get HER to work on the honeydo.... Surely you jest ... In all fairness she does... she just fails to see the things that really need to get done. Like cleaning up for plow day... 1 5 Share this post Link to post Share on other sites
ebinmaine 70,684 #12 Posted October 1, 2024 13 minutes ago, wallfish said: Never ever never knock too much off that honey do list because it will NEVER get smaller anyway. Pace yourself and make LEGITIMATE EXCELLENT REASONS if necessary. I fixed it for ya... 4 Share this post Link to post Share on other sites
wallfish 17,485 #13 Posted October 1, 2024 Just now, ebinmaine said: I fixed it for ya... My excuses are never "legitimate" but the beauty of it is, she don't know that 4 Share this post Link to post Share on other sites
squonk 42,508 #14 Posted October 1, 2024 9 hours ago, WHX?? said: Surely you jest ... In all fairness she does... she just fails to see the things that really need to get done. Like cleaning up for plow day... So who cleans up AFTER plow day? 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,496 #15 Posted October 1, 2024 Honey do lists not complete??? Oh you brave and silly men... My personal approach is to always have the list caught up... cuts down on the 3 1 Share this post Link to post Share on other sites
lynnmor 7,557 #16 Posted October 1, 2024 Sounds like someone needs to turn in their man card. 5 Share this post Link to post Share on other sites
WHX?? 50,698 #17 Posted October 1, 2024 2 hours ago, squonk said: So who cleans up AFTER plow day? Well ummm ahhh... she's the one who wants 30,000 crock pots full of food... I tell her these clowns will eat $h*% sammiches with the right ketchup... 21 minutes ago, lynnmor said: Sounds like someone needs to turn in their man card. Turned and burned long ago.... 4 Share this post Link to post Share on other sites
ebinmaine 70,684 #18 Posted October 1, 2024 1 hour ago, lynnmor said: Sounds like someone needs to turn in their man card. I never even got one!! 47 minutes ago, WHX?? said: Well ummm ahhh... she's the one who wants 30,000 crock pots full of food... I tell her these clowns will eat $h*% sammiches with the right ketchup... Who needs ketchup 😋 2 Share this post Link to post Share on other sites
oliver2-44 10,353 #19 Posted October 1, 2024 2 hours ago, SylvanLakeWH said: My personal approach is to always have the list caught up... cuts down on the No sure if I should ask what are your smoking, or dreaming. Same thing I guess. 2 Share this post Link to post Share on other sites
