WHX?? 49,101 #101 Posted Sunday at 02:25 AM I like that power outlet havta look for those. Just don't t try battery tending through it tho ... don't ask me how I know... 54 minutes ago, Bar Nuthin said: lighted toggle switch Yah I got abit carried away too... In the cab of a 520 with light bars ... 2 Share this post Link to post Share on other sites
kpinnc 12,342 #102 Posted Sunday at 02:30 AM 4 minutes ago, WHX?? said: Yah I got abit carried away too... In the cab of a 520 with light bars ... Necessities are never too much! 1 1 Share this post Link to post Share on other sites
Bar Nuthin 416 #103 Posted Sunday at 02:36 AM (edited) 18 minutes ago, WHX?? said: Just don't t try battery tending through it tho ... don't ask me how I know... Sorry, but I gotta ask. I haven't had any issues (yet) - but I sure would like to avoid any in the future!! Amazon.com: ELFCULB 2FT 10AWG SAE Power Socket Sidewall Port to O Ring Connecters Extension Cord Cable with 10A 15A 20A 25A 30A Fuse Compatible with Solar Generator Battery Charger,for Solar Accessories : Patio, Lawn & Garden Edited Sunday at 02:45 AM by Bar Nuthin added link Share this post Link to post Share on other sites
ebinmaine 68,137 #104 Posted Sunday at 02:51 AM 1 hour ago, Bar Nuthin said: plan to add at least one 2-prong connector for accessories like my weed sprayer, battery tender, and maybe an amber beacon light. Neat idea. Can you share more info or links? Share this post Link to post Share on other sites
Bar Nuthin 416 #105 Posted Sunday at 02:55 AM (edited) 7 minutes ago, ebinmaine said: Neat idea. Can you share more info or links? here's the one I used Amazon.com: ELFCULB 2FT 10AWG SAE Power Socket Sidewall Port to O Ring Connecters Extension Cord Cable with 10A 15A 20A 25A 30A Fuse Compatible with Solar Generator Battery Charger,for Solar Accessories : Patio, Lawn & Garden Direct connection from battery - through toggle switch - to receptacle. I used my own fuses - some wuhan stuff I just don't trust. Wired a 12AWG cord to my weed sprayer. Amazon.com: ELFCULB 12AWG 6FT SAE Extension Cable 3 6 10 20 35 50FT SAE to SAE Quick Disconnect Wire Harness SAE Connector SAE Plug for Automotive RV Battery Solar Panel (6FT) : Patio, Lawn & Garden Edited Sunday at 02:59 AM by Bar Nuthin 1 Share this post Link to post Share on other sites
WHX?? 49,101 #106 Posted Sunday at 03:38 AM Howd you know I was gonna look in the jungle.?!?! When the power outlet is connected as a outlet the pins are reversed for use with a tender with the same two prong plug that many have. I connected one to tend the battery on the camper. Not thinkin and forgot it was a innie NOT an outie at a show I plugged the 12v camp smoker in ... and promptly burned out the buck & a quarter control module that was not polarity protected. Next show @Achto made me check it first and told me I should have just plugged it in a horse cigar lighter! 3 Share this post Link to post Share on other sites
ebinmaine 68,137 #107 Posted Sunday at 12:53 PM 9 hours ago, WHX?? said: When the power outlet is connected as a outlet the pins are reversed for use with a tender with the same two prong plug that many have Now that there's some extremely important information! The only two prong plugs I've ever seen are squared on a side AND the wire color is visible so they can't be reversed. Share this post Link to post Share on other sites
Bar Nuthin 416 #108 Posted Sunday at 03:16 PM 11 hours ago, WHX?? said: When the power outlet is connected as a outlet the pins are reversed for use with a tender with the same two prong plug that many have. Hmmm. The polarity on mine are correct - but that probably explains why they include a crossover with the cable I bought. Problem is, you'd have to remember to use it. I've been told that as I get older, that memory is the second thing to go. I can't remember what the first thing was. 2 Share this post Link to post Share on other sites
WHX?? 49,101 #109 Posted Monday at 02:19 AM (edited) 14 hours ago, ebinmaine said: AND the wire color is visible so they can't be reversed. They can't be reversed but you can have the other end connected to the battery reversed. I was wondering what that gizmo was for Nuthin. I thought it was to connect two extensions together. I would ring that out before I used it to reverse polarity. Never have to I would have it long lost or forgot where i put it when I needed it... Edited Monday at 03:02 AM by WHX?? 1 Share this post Link to post Share on other sites
