Milosz 3 #1 Posted September 29, 2024 Hello I have owned a 706 for some time now. Unfortunately, I only have a trailer for it and no tools are available for purchase in my area. I would like to make a snow plow myself based on the original. I found a photo on the internet but I have a request. Could someone who has one measure the frame elements exactly? Greetings from Poland! 1 Share this post Link to post Share on other sites
ri702bill 10,565 #2 Posted September 29, 2024 Milosz - Welcome. That is a VERY ambitious project. You also need the rear axle quick mount. And - the angling lever & rod are not shown - you need them too. A suggestion - are you better off modifying a different brand, but similar size plow to fit your needs??? Perhaps @gwest_ca can supply documentation. 1 Share this post Link to post Share on other sites
Milosz 3 #3 Posted September 29, 2024 39 minutes ago, ri702bill said: Milosz - Welcome. That is a VERY ambitious project. You also need the rear axle quick mount. And - the angling lever & rod are not shown - you need them too. A suggestion - are you better off modifying a different brand, but similar size plow to fit your needs??? Perhaps @gwest_ca can supply documentation. I have already found the rear axle dimensions on the forum and I will make one without any problems. I already have an idea and material for the plow. But I still need frame dimensions to make the task easier and not do it haphazardly. Angle change levers won't be a problem Share this post Link to post Share on other sites
ri702bill 10,565 #4 Posted September 29, 2024 Sounds like you have a handle on this.... keep us posted on your progress. Share this post Link to post Share on other sites
Milosz 3 #5 Posted September 29, 2024 As soon as I find time to do it, I will definitely post some photos 1 Share this post Link to post Share on other sites
peter lena 9,555 #6 Posted September 29, 2024 @Milosz done a couple of those , the STEERING QUADRANT area ,front end of frame pull lever activated is critical for blade swing ease . like a red grease in movement points , that lever spring pull , should slide like a rifle bolt . done this on my set ups , also oil soak the front of the blade , for snow release , stop rust , build it while its hanging on the tractor , use a roller stool to get a FUNCTIONAL LOOK at how its working . let someone else move the plow to show you , what needs improvement . works with total ease , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,841 #7 Posted September 29, 2024 The blade at the time was this model Even the last blades in 2001 were made to fit the early short frame tractors by moving the rear cross bar. 1 Share this post Link to post Share on other sites
Ed Kennell 43,773 #8 Posted September 29, 2024 to the Milo. This may help you get started. 2 1 Share this post Link to post Share on other sites
Milosz 3 #10 Posted September 30, 2024 10 hours ago, Ed Kennell said: to the Milo. This may help you get started. Great! Man this is what i looking for. Thanks a lot! 1 Share this post Link to post Share on other sites
peter lena 9,555 #11 Posted September 30, 2024 @Miloszhttps://www.google.com/search?q=hitch+pin+clips&rlz=1C1CHBF_enUS866US866&oq=hitch+pin+cl&gs_lcrp=EgZjaHJvbWUqDAgAECMYJxiABBiKBTIMCAAQIxgnG this is the type of pin you want in your rear frame to tractor lever hook up , also install the pin all the way in , to the last large hole , it won't fall out there . lubricate any movement point as you go. that side view , of frame on tractor , sitting on a roller stool , lets you scoot around to see what's going on ! and build in you detailing . believe it or not , those plows can swing / move with total ease .from the right hand squeeze lever , can / should work with solid/ smooth spring pressure , starting in the quadrant spring / pin slide area , penetrating oil first , then aerosol RED GREASE , for very easy blade swing , turn over plow blade lower wear strip , if you can , for a fresh start . oil blade finish for snow release / stop rust , pete 1 Share this post Link to post Share on other sites
