Easton Rich
MY FIRST WH PURCHASE!
Retired Wrencher
3 hours ago, ebinmaine said:
Send it to me and I'll see what can be done.
You are a good man Eric. I know because you have done many of my carbs. I have small part drop idees.
Easton Rich
All right, I brought it home today and changed the tranny fluid, adjusted the clutch and put the new carb on. The number on it is 6105 can I get a year or number of tractor?
ebinmaine
Where's that number from?
Can you post a pic of the ID Tag?
Easton Rich
Yes
Easton Rich
Easton Rich
Easton Rich
Lee1977
Looks good, only needs a good clean up and polish that paint should brighten up.
ebinmaine
33 minutes ago, Easton Rich said:
This seat looks GREAT!
ebinmaine
39 minutes ago, Easton Rich said:
What I do is put that first half of the top number in the search box above.
" 61 o8k8o2 "
Hit search, but then hit "and" ...
There are ways to check "files" too but I don't remember how.
I'd say you have a 1976 B80 8 speed.
Easton Rich
So the 6105 at the bottom doesn’t have meaning?
ebinmaine
I'm sure it does but not to the year, make model designation.
Easton Rich
Ok, thanks!
WHGuy413
B-80’s are great tractors. We have a couple here.
Easton Rich
@ebinmaine here are a couple projects if you want them. Both for a b80
Easton Rich
ebinmaine
Send me a PM.
I'd be glad to help.
Easton Rich
I’m planning to paint it soon, if you have any suggestions on colors or paint prep all is appreciated :)
ebinmaine
There's a ton of info in various threads.
How precise are you looking to be?
953 nut
Preparation is the first key to a successful finish.  Perseverance is the second. A few years back @JPWH did a thread on the rebuild of his 854. A good portion of it5 was devoted to paint prep and application. This thread should be a god read and furnish a lot of great information.
Here are twenty five threads on paint color selection that have come up here lately.
https://www.wheelhorseforum.com/search/?q=paint color&type=forums_topic&nodes=45&updated_after=any&sortby=relevancy&search_and_or=and&search_in=titles
Easton Rich
I’d like to make as nice as I can for 200-300 dollars. If that gives you an idea
Easton Rich
Finally got that thread read, thanks 953 that helped. Is there a difference between regal red and international red?
953 nut
The only way you would see any difference would be if you sprayed them on the same piece. Either one is fine.
Easton Rich
I’ll tat sanding Friday
Easton Rich
I got two colors of primer
