Easton Rich 768 #1 Posted September 27, 2024 Alright, I finally bought one without asking you guys 27 million questions. It’s a b80 8 speed for 350 dollars. Runs drives but needs a new carburetor that it comes with. I will show pictures this week. This is my second WH 10 2 Share this post Link to post Share on other sites
ebinmaine 75,713 #2 Posted September 27, 2024 Niiiiice 1 Share this post Link to post Share on other sites
Easton Rich 768 #3 Posted September 27, 2024 Ill make sure to post pictures 1 Share this post Link to post Share on other sites
Easton Rich 768 #4 Posted September 27, 2024 I’m getting t Saturday 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,938 #5 Posted September 27, 2024 A fine machine! 1 Share this post Link to post Share on other sites
Easton Rich 768 #6 Posted September 27, 2024 I plan to restore it soon as a 4h project. I’m the only one in small engines in my county so its easy to when 1 2 Share this post Link to post Share on other sites
Lee1977 7,456 #8 Posted September 27, 2024 (edited) The B-80 is a great tractor same basic tractor as the C-series. The C's just have a larger engine, high back seat, and lights, Don't think the B had lights unless it was a special order. The B-80 8 speeds were only made in 1976 and 1977. The model numbers start wit either a 61 or 71. Edited September 27, 2024 by Lee1977 2 Share this post Link to post Share on other sites
ebinmaine 75,713 #9 Posted September 27, 2024 3 hours ago, Lee1977 said: The B-80 is a great tractor same basic tractor as the C-series. The C's just have a larger engine, high back seat, and lights, Don't think the B had lights unless it was a special order. The B-80 8 speeds were only made in 1976 and 1977. The model numbers start wit either a 61 or 71. Steering wheel may have been a little smaller on a B Series too. Not sure. 1 Share this post Link to post Share on other sites
Racinbob 12,422 #10 Posted September 27, 2024 The 76 and 77 B-series was really quite a bargain. As mentioned they are identical to the C-series as far as the frame, transmission, and sheetmetal. The differences: Horsepower B's had 22-7.50 rear tires vs 23-8.5 on the C's. If you opted for the cleat rears they were all 23-8.50 Low back seat vs high back Headlights optional on the B's 13" steering wheel vs 15" Prior to 76 the B's had a shorter frame and were 4-speeds with the 1" axle Starting in 78 the B's became lawn tractors 5 Share this post Link to post Share on other sites
Pullstart 68,521 #11 Posted September 27, 2024 Congrats on your score! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,980 #12 Posted September 27, 2024 Love mine! 5 5 Share this post Link to post Share on other sites
rmaynard 16,690 #13 Posted September 27, 2024 3 hours ago, ebinmaine said: Steering wheel may have been a little smaller on a B Series too. Not sure. Same size as all the others. 1 Share this post Link to post Share on other sites
WHX?? 53,294 #14 Posted September 27, 2024 Congrats on picking up a fine tractor! I had a '73 no name that was the start of the B series and a fine fine little tractor. I called it Aunt B and I'm not one to name my tractors ... just the special ones. I set it up with proper tires for field plowing and what a nice job it did. Pulled a 10 & 8 incher with no problem. These 8's can do just about anything a big tractor can. Definitely one of those "wished I never sold it" tractors ...you guys know! 4 Share this post Link to post Share on other sites
Easton Rich 768 #15 Posted September 27, 2024 Thank you so much! 2 Share this post Link to post Share on other sites
Achto 30,177 #16 Posted September 27, 2024 12 hours ago, Easton Rich said: Runs drives but needs a new carburetor Congrat's on your new tractor!! Needs a new carb or needs the original one rebuilt?? I would try to rebuild the original carb. Make sure to use a factory rebuild kit. Feel free to ask any questions on rebuilding the carb. 3 1 Share this post Link to post Share on other sites
WHX?? 53,294 #17 Posted September 27, 2024 (edited) 29 minutes ago, Achto said: try to rebuild the original carb. Although I have had good luck with the cheapy offshore knockoffs the general consensus here is to try and save a original. and run what ya brung. Might just need a good cleaning. Edited September 27, 2024 by WHX?? 3 Share this post Link to post Share on other sites
Keaton 466 #18 Posted September 27, 2024 @Easton Rich I just got a few more, and I'm in 4h its fun, just got to get them done I time. wheel horses are fun and figuring out how they work is even more fun. every tractor is different, wheel horses seem to be one of the most simple that I have 3 Share this post Link to post Share on other sites
Racinbob 12,422 #19 Posted September 27, 2024 4 hours ago, rmaynard said: Same size as all the others. In 76 & 77 the B's had a 13" steering wheel. C's had a 15". 🙂 1 Share this post Link to post Share on other sites
D_Mac 9,330 #20 Posted September 27, 2024 My first was a beautiful red head. 308-8 3 Share this post Link to post Share on other sites
ebinmaine 75,713 #21 Posted September 27, 2024 3 hours ago, Achto said: Congrat's on your new tractor!! Needs a new carb or needs the original one rebuilt?? I would try to rebuild the original carb. Make sure to use a factory rebuild kit. Feel free to ask any questions on rebuilding the carb. 2 hours ago, WHX?? said: I've very few bad things about the small block aftermarket carbs but the 10 - 16 HP carbs I've personally seen at least 4 that were no good. I won't use another one. If you need any hints tips tricks etc on your own carb do feel free to ask. 2 1 Share this post Link to post Share on other sites
kpinnc 16,176 #22 Posted September 27, 2024 16 hours ago, Easton Rich said: Alright, I finally bought one Welcome to the sickness! A B-80 is a solid machine. If the K181 isn’t enough for you, You just add a bigger engine later. That 8-speed can handle way more if you need it. 2 Share this post Link to post Share on other sites
rmaynard 16,690 #23 Posted September 27, 2024 6 hours ago, Racinbob said: In 76 & 77 the B's had a 13" steering wheel. C's had a 15". 🙂 I'm going to have to disagree. I've had 3 B-80', 4 B-100's, and 2 C-120's. They all had a 13" soft touch steering wheel, #102715. After the C-1x1 series came out in 1978, they switched to a hard plastic, 3-spoke wheel, #106055. It may have been a larger diameter. Share this post Link to post Share on other sites
Easton Rich 768 #24 Posted September 28, 2024 The carb adjustment screw is broken off otherwise I would rebuild it Share this post Link to post Share on other sites
ebinmaine 75,713 #25 Posted September 28, 2024 3 hours ago, Easton Rich said: The carb adjustment screw is broken off otherwise I would rebuild it Send it to me and I'll see what can be done. 3 Share this post Link to post Share on other sites
