mrc 1,015 #1 Posted September 26, 2024 hello all, i just learned that the simsbury ct small airport has ethanol free gas. i was told they would sell to the general public in approved gas containers.. the only catch is, if they ask you tell them the gas is for your airplane. i do not know how much it costs or what octane. the phone number is 860-459-1575 hope this helps us all. sparky, maquest says the airport is 33 miles from andover. regards mike in mass. but, i work in ct 2 2 2 Share this post Link to post Share on other sites
WHX?? 53,327 #2 Posted September 26, 2024 3 hours ago, mrc said: do not know how much it costs or what octane. Call em Sparky and find out ... might be quite proud of it. Guessing octane in the low nineties. 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,939 #3 Posted September 26, 2024 @mrcI’m sure @Sparky would appreciate the tip. He puts in some serious miles to get the good stuff. 2 Share this post Link to post Share on other sites
mrc 1,015 #4 Posted September 27, 2024 i live about 40-45 miles from the NY state border. not far across the mass/ny border is a small town called new lebanon NY. they sell 91 octane ethanol free gas. i think i paid $4.00 -$4.50 a gallon last time i was there. not only do i use it in my wheelhorses but i fill up my old caddy prior to winter storage. i'm going to try this little airport next time i need real gas as i work fairly close by. the extra travel and expense is a pain but, no ethanol issues. regards mike 2 Share this post Link to post Share on other sites
Wild Bill 633 899 #5 Posted September 27, 2024 https://www.pure-gas.org Share this post Link to post Share on other sites
CCW 1,454 #6 Posted September 28, 2024 On 9/26/2024 at 6:14 AM, mrc said: i just learned that the simsbury ct small airport has ethanol free gas. Well now this is good news since I live in Simsbury and the airport is less than ten minutes away. 1 Share this post Link to post Share on other sites
Bill D 2,442 #7 Posted September 28, 2024 Probably selling 100 octane low lead gas 1 Share this post Link to post Share on other sites
kpinnc 16,187 #8 Posted September 29, 2024 7 hours ago, Bill D said: Probably selling 100 octane low lead gas Yeah I’d definitely be mindful of the octane rating since it’s primarily for aircraft. Avgas is definitely not the same as standard ethanol-free “rec fuel”. 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #9 Posted September 29, 2024 On 9/26/2024 at 6:33 PM, EB-80/8inPA said: @mrcI’m sure @Sparky would appreciate the tip. He puts in some serious miles to get the good stuff. Must have a “dealer”… 1 Share this post Link to post Share on other sites
siebenaler 114 #10 Posted September 29, 2024 That's all I use in my truck 3.68 a gallon here 2 Share this post Link to post Share on other sites
ebinmaine 75,747 #11 Posted September 29, 2024 8 hours ago, kpinnc said: Yeah I’d definitely be mindful of the octane rating since it’s primarily for aircraft. Avgas is definitely not the same as standard ethanol-free “rec fuel”. There are LOTS of folks on the all-knowing interwebs that'll argue the virtues of octane til the cows come home. 🐄🐮 I've been under the impression that using a higher octane rating in a non computer controlled engine does no harm. It simply slows the burn event down immediately after the spark plug fires. I'm absolutely open to proven answers either way on that. 1 Share this post Link to post Share on other sites
Lagersolut 769 #12 Posted September 29, 2024 3 hours ago, ebinmaine said: There are LOTS of folks on the all-knowing interwebs that'll argue the virtues of octane til the cows come home. 🐄🐮 I've been under the impression that using a higher octane rating in a non computer controlled engine does no harm. It simply slows the burn event down immediately after the spark plug fires. I'm absolutely open to proven answers either way on that. It seems the aviation gas is still burning lead as a lubricant Quote Aviation gas still contains tetra-ethyl lead additives to lubricate the engine. Lead was taken out of automotive gas in 1986. Avgas still contains lead because a suitable alternative hasn’t been found yet, despite years of testing. Using leaded avgas in a modern car would ruin components such as the catalytic converter. Conversely, Jet-A wouldn’t work in a gas engine. It would be like putting diesel fuel in your gas-powered car, it just won't run. However, Jet-A could be used in diesel-engine vehicles, but it lacks some of the lubricants found in road diesel fuel. https://www.mcico.com/resource-center/articles/jet-fuel-vs-gasoline 1 Share this post Link to post Share on other sites
peter lena 9,556 #13 Posted September 29, 2024 @mrc since using STA BIL in all my small engine , equipment , the first thing you notice is , no fuel hose debris , in the fuel bowl . my first experiment with it was to clean out existing fuel sediment areas , tank , carb , so I could verify its storage claims . replaced old hoses , fresh filters , since that change over there has been zero / no debris in filters , or carb bowl , adding an ounce of STABIL to all my fuel tank top offs , lets me use regular ethanol gas , without any issues , isn't that what you want ? run 3 engines on this set up , regular gas , stabil is made for storage , chemical make up , has worked for me . as stated replaced filters , old hoses , cleaned tanks , no fuel hose debris in any holding area . buy the large bottle of stabil , add it to all my fuels , no distance travel involved . run my stuff year round , no fuel issues , my generator also uses it , fuel filter / carb bowl / clean clear , just sayin . pete 2 Share this post Link to post Share on other sites
